Error while implementing own tensor volume field.
Old   June 22, 2020, 06:36
Default Error while implementing own tensor volume field.
Matias Haapalehto
haapalm is on a distinguished road
I have implemented my own rank 4 tensor class (i.e. tensorRank4) , and I added these typedefs to (naively?) create volume fields:
typedef GeometricField<tensorRank4, fvPatchField, volMesh> volTensorRank4Field;
typedef dimensioned<tensorRank4> dimensionedTensorRank4;
When I try to instantiate the field using:
volTensorRank4Field a4
         IOobject
          "a4",
          runTime.timeName(),
          mesh,
          IOobject::NO_READ,
          IOobject::AUTO_WRITE
         mesh,
         dimensionedTensorRank4("a4", dimensionSet(0,0,0,0,0,0,0),
             tensorRank4::zero)
I get these compilation erros:
error: no match for call to ‘(const Foam::fvPatchFieldMapper) (Foam::fvPatchField<Foam::TensorRank4<double> >&, Foam::fvPatchField<Foam::TensorRank4<double> >&)’
  213 |     mapper(*this, *this);
And
/scratch/work/haapalm3/OpenFOAM-7/src/finiteVolume/lnInclude/fvPatchField.C:213:11: note:   ‘Foam::fvPatchField<Foam::TensorRank4<double> >’ is not derived from ‘const Foam::tmp<Foam::Field<Type> >’
haapalm is offline   Reply With Quote
simpleDyMFoam on v1806 gamemakerh OpenFOAM Programming & Development 0 November 8, 2018 09:15
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 09:34
Steady simulation does not iterate in Time=1 agustinvo OpenFOAM Running, Solving & CFD 3 November 19, 2015 05:57
[General] How to create an additional vector with {Field 4, Field 5, Field 6} Bombacar ParaView 1 August 15, 2015 19:05
Demagnetization field jan0385 ANSYS 0 April 12, 2012 10:09
