problems coming from the new version of OpenFOAM (v7))
Old   June 22, 2020, 00:03
Default problems coming from the new version of OpenFOAM (v7))
Wenming Yang
ywem is on a distinguished road
Dear formers,
Recently I tried to transplanted a previous programmed solver, which is run well in OpenFOAM 5.0, to the newest version, OpenFOAM v7. The following problems were encountered,
1. the class fvMesh does not have a member function solver(). So the sentence
pEqn.solve(mesh.solver(p.select(piso.finalInnerIte r())));
(in the header file pEqn.H of solvers such as pisoFoam)
cannot been executed. This was solved by using
pEqn.solve( );
instead.
2. An executing of BC codeStream as
upWall
type fixedValue;
value #codeStream
codeInclude
#include "fvCFD.H"
codeOptions
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
codeLibs
-lmeshTools \
-lfiniteVolume
code
const IOdictionary& d = static_cast<const IOdictionary&>
dict.parent().parent()
const fvMesh& mesh = refCast<const fvMesh>(d.db());
const label id = mesh.boundary().findPatchID("upWall");
const fvPatch& patch = mesh.boundary()[id];
scalarField potenH(patch.size(), scalar(0));
const scalar H_0 = 1.4835e3;
const scalar h = 0.2e-3;
forAll(potenH,i)
const scalar x = patch.Cf()[i][0];
potenH[i] = scalar(0. - H_0*h - 0.2*H_0*x);
potenH.writeEntry("", os);
encounted the following problem
Failed wmake "dynamicCode/_63e33dcbd665576f46bbc4b2803f07eb39c7605b/platforms/linux64GccDPInt32Opt/lib/libcodeStream_63e33dcbd665576f46bbc4b2803f07eb39c7 605b.so"
file: /home/yw/OpenFOAM/ym-7/run/SelfProgrammedSolvers/fhdFoam/fhdTut/2_channelFlowGradientField/2H0ByFoam/0/potenH.boundaryField.upWall from line 35 to line 35.
From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 215.
FOAM exiting
and this problem was not solved. Does anyone has ideas? Thank you in advance.
ywem is offline   Reply With Quote
Old   June 22, 2020, 02:01
bestucan's Avatar
Tu Can
bestucan is on a distinguished road
here is an upgrade guide from openfoam.com
openfoam.com user-upgrade-guide
and release notes from openfoam.rog
openfoam.org history
may help.
bestucan is offline   Reply With Quote
Old   June 22, 2020, 04:54
Wenming Yang
Dear Bestucan,
Thanks for your reminder.
The problem 2 was finially addressed by replacing "potenH.writeEntry("", os)" with "writeEntry(os, "", potenH)" and it works well now.
boundary conditions, codestream, new version of openfoam, openfoam v7
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[Gmsh] gmshToFoam on openfoam windows version of OpenFOAM v1812? SihunLee OpenFOAM Meshing & Mesh Conversion 0 June 17, 2019 06:44
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
Convergence Problems using Spalart Allmaras recnice OpenFOAM Running, Solving & CFD 3 October 9, 2013 13:19
