Implementations of source terms into enengy equation
Old   May 29, 2020, 10:10
Default Implementations of source terms into enengy equation
Huihui Xiao is on a distinguished road
Hello Foamer,
I try to incorporate the evaporation model into OpenFOAM based on the interFoam solver. The theory is based on ''Hardt, S., et al. (2008). J Comput Phys 227(11): 5871-5895.''. Actually, I checked the source code of ''evapVOFHardt'' solver which implements the evaporation model very well.
In the evapVOFHardt solver (TEqn.H), they calculated the latent heat term by decomposing -1*(mass source term)*(Enthalpy of vaporization) into hESource*T - hESource*Tsat, and calculate them as implicit and explicit terms respectively.
Actually, I know this method works, however, I tried to calculate the latent heat with a direct way, i.e. using the single explicit term ''-1*(mass source term)*(Enthalpy of vaporization) ''. But I got something strange there when I validate the solver with 1D stefan problem, and the problem is that I got the minimum temperature around 369.677 K (for the BCs in my case (Left wall temperature : 383.15 K, and the rest is 373.15K )), and the simulation was really slow although we can see the interface was moving.
Could you please tell me why I got the strange results? Thank you so much.
Huihui Xiao is offline   Reply With Quote
Old   February 11, 2022, 08:51
Aman Kumar Jain
amjain is on a distinguished road
How did you solve this problem? I am having a similar issue.
amjain is offline   Reply With Quote
energy equation, evaporation, openfoam
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
