CLSVOF from OF23x to OF231
Old   May 20, 2020, 13:29
Default CLSVOF from OF23x to OF231
X
mcfdma is on a distinguished road
Greetings.
So I have been referring this report to understand CLSVOF.
http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf
However, I am using OF231 and this solver was created on OF23x.
The solver compiles perfectly with OF23x but when I try to compile with OF231, I am getting an error. I tried looking at all files based on the errors but could not figure out the issue.
Making dependency list for source file sclsVOFFoam.C
SOURCE=sclsVOFFoam.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam231/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam231/src/transportModels -I/opt/openfoam231/src/transportModels/incompressible/lnInclude -I/opt/openfoam231/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam231/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam231/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam231/src/finiteVolume/lnInclude -I/opt/openfoam231/src/fvOptions/lnInclude -I/opt/openfoam231/src/meshTools/lnInclude -I/opt/openfoam231/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam231/src/OpenFOAM/lnInclude -I/opt/openfoam231/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/sclsVOFFoam.o
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDiv.C:29:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDiv.H:180,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDDt.C:27,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcDDt.H:76,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:45,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvCFD.H:8,
                 from sclsVOFFoam.C:40:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/divScheme.H: In constructor ‘Foam::fv::divScheme<Type>::divScheme(const Foam::fvMesh&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/divScheme.H:111:32: error: expected type-specifier before ‘linear’
             tinterpScheme_(new linear<Type>(mesh))
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcGrad.C:29:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcGrad.H:124,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:49,
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H: In constructor ‘Foam::fv::gaussGrad<Type>::gaussGrad(const Foam::fvMesh&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H:88:32: error: expected type-specifier before ‘linear’
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H: In constructor ‘Foam::fv::gaussGrad<Type>::gaussGrad(const Foam::fvMesh&, Foam::Istream&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H:101:21: error: expected primary-expression before ‘(’ token
/opt/openfoam231/src/transportModels/incompressible/lnInclude/gaussGrad.H:102:29: error: expected type-specifier before ‘linear’
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.H:150:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/laplacianScheme.H:42,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcLaplacian.C:28,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcLaplacian.H:242,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:53,
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C: In member function ‘Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fv::correctedSnGrad<Type>::fullGradCorrection(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:9: error: ‘linear’ was not declared in this scope
       & linear<typename outerProduct<vector, Type>::type>(mesh).interpolate
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:9: note: suggested alternative:
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcAverage.C:29:0,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcAverage.H:91,
                 from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvc.H:42,
/opt/openfoam231/src/transportModels/incompressible/lnInclude/linear.H:52:7: note:   ‘Foam::compressibilityModels::linear’
 class linear
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:57: error: expected ‘(’ before ‘>’ token
/opt/openfoam231/src/transportModels/incompressible/lnInclude/correctedSnGrad.C:54:65: error: ‘const class Foam::fvMesh’ has no member named ‘interpolate’
In file included from /opt/openfoam231/src/transportModels/incompressible/lnInclude/fvcLaplacian.C:28:0,
/opt/openfoam231/src/transportModels/incompressible/lnInclude/laplacianScheme.H: In constructor ‘Foam::fv::laplacianScheme<Type, GType>::laplacianScheme(const Foam::fvMesh&)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/laplacianScheme.H:113:37: error: expected type-specifier before ‘linear’
             tinterpGammaScheme_(new linear<GType>(mesh)),
In file included from createFields.H:105:0,
                 from sclsVOFFoam.C:66:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/createPhi.H: In function ‘int main(int, char**)’:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/createPhi.H:49:24: error: ‘linearInterpolate’ was not declared in this scope
     linearInterpolate(U) & mesh.Sf()
In file included from sclsVOFFoam.C:66:0:
createFields.H:162:13: error: ‘incompressible’ was not declared in this scope
     autoPtr<incompressible::turbulenceModel> turbulence
createFields.H:162:44: error: template argument 1 is invalid
createFields.H:163:5: error: invalid type in declaration before ‘(’ token
createFields.H:164:9: error: ‘incompressible’ is not a class or namespace
         incompressible::turbulenceModel::New(U, phi, mixture)
In file included from sclsVOFFoam.C:70:0:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/CourantNo.H:51:1: error: ‘namespace’ definition is not allowed here
 namespace Foam
In file included from sclsVOFFoam.C:71:0:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/setInitialDeltaT.H:35:40: error: ‘CoNum’ was not declared in this scope
     if ((runTime.timeIndex() == 0) && (CoNum > SMALL))
In file included from sclsVOFFoam.C:99:0:
setDeltaT.H:37:20: error: ‘CoNum’ was not declared in this scope
         min(maxCo/(CoNum + SMALL), maxAlphaCo/(alphaCoNum + SMALL));
In file included from sclsVOFFoam.C:121:0:
UEqn.H:5:19: error: base operand of ‘->’ is not a pointer
       + turbulence->divDevRhoReff(rho, U)
sclsVOFFoam.C:131:18: error: base operand of ‘->’ is not a pointer
        turbulence->correct();
In file included from sclsVOFFoam.C:67:0:
/opt/openfoam231/src/transportModels/incompressible/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
 scalar maxDeltaT =
make: *** [Make/linuxGccDPOpt/sclsVOFFoam.o] Error 1
Any hints??
mcfdma is offline   Reply With Quote
Old   May 20, 2020, 14:36
Hasan Celik
PositronCascade is on a distinguished road
There might be a change in fvCFD.H file between two versions and that might be causing error due to change of some definitions, constructors etc.
Originally Posted by mmalik View Post
Greetings.
 class linear
 namespace Foam
 scalar maxDeltaT =
Any hints??
PositronCascade is offline   Reply With Quote
Old   May 20, 2020, 14:45
X
Thank you for the quick response. I had a look at both fvCFD.H versions and they are identical.
clsvof, clsvoffoamsf
CLSVOF in InterFoam kalaikdr OpenFOAM Running, Solving & CFD 27 September 2, 2021 01:13
CLSVOF - for capillary rise kuria OpenFOAM Verification & Validation 4 July 12, 2021 08:40
Initialization of the LS function, CLSVOF in Fluent Sufyan FLUENT 0 August 1, 2018 05:53
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
CLSVOF on star-ccm+ tayo STAR-CCM+ 5 September 18, 2012 07:42
