finite area method, depth averaged model
Old   May 19, 2020, 13:38
Default finite area method, depth averaged model
Geb1313 is on a distinguished road
Hi foamers,
I am developing (with a colleague) a depth average flow model for viscoplastic debris flow ( fluids with yield stress) based finite area method libraries. The flow model has a two years of the same material; layer 1, a shearing layer with hs and layer 2, plug layer with hp and the total depth of flow is h = hp+hs. One of the physical equation is:
\frac{\partial U_p}{\partial t} + U_p . \nabla U_p + g \nabla h = g_s -\frac{ U_p}{|U_p|} \frac{ \tau_y}{\rho* h_p}
I coded it as:
[/fam::ddt(Up)
+ Up & fac::grad(Up)
+ 1. 0/ rho * fam::Sp(tau0 / ((hp+h0)*(mag(Up) + u0)), Up)
And I got the following compiling error:
error: no match for ‘operator+’ (operand types are ‘Foam::tmp<Foam::GeometricField<Foam::Tensor<doubl e>, Foam::faPatchField, Foam::areaMesh> >’ and ‘Foam::tmp<Foam::faMatrix<Foam::Vector<double> > >’)
+ 1. / rho * fam::Sp(tau0 / ((hp+h0)*(mag(Up) + u0)), Up)
Is there any way to write \ U_p . \nabla U_p in openfoam?
Geb1313 is offline   Reply With Quote
Old   May 19, 2020, 14:28
I tried to derive an alternative expression from:
\nabla . U_p U_p =U_p .\nabla U_p  +U_p(\nabla .U_p)
Rearranging:
U_p .\nabla U_p = \nabla . U_p U_p - U_p(\nabla .U_p)
Then I coded it as:
[ fam::ddt(Up)
+ fam::div(phip, Up)
- fam::Sp(fac::div(phip), Up)
gs
- gn * fac::grad(h)]
where gn = g & n( normal) and gs = g -gn &n
The compilation went Ok. However a run on a trial case of 1D flume with inlet and outlet gave the following log:
Courant Number mean: 0.000277993 max: 0.000277993 velocity max magnitude: 0.0138996
deltaT = 0.000120482
Time = 0.000120482
DILUPBiCG: Solving for Upx, Initial residual = 1, Final residual = 1.53502e-17, No Iterations 1
DILUPBiCG: Solving for Upy, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Upz, Initial residual = 0, Final residual = 0, No Iterations 0
It stopped without warning. it couldn't continue to the next equation.
Any help please!
Thanks,
Gebray
finite area method
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
finite area method doesn't work in parallel (foam-extend-4.0) andlog OpenFOAM Bugs 8 December 11, 2017 12:04
The finite element method - “displacement” or “stiffness” method 3Lin7 ANSYS 0 February 15, 2013 19:36
The aspect ratio of the volume elements in Finite Volume Method CharlieTan84 Main CFD Forum 3 August 28, 2012 03:34
finite volume method co2 FLUENT 0 March 1, 2004 13:24
