The displacement of the grid node in the z direction |
May 8, 2020, 05:49 |
Fan
Rep Power: 6 |
Hi folks,
I want to konw, can you modify the grid points by judging the speed in the grid points? for example, when the speed reaches a certain value, modify the grid z direction. Thanks |
May 12, 2020, 17:29 |
Herpes Free Engineer
Rep Power: 13 |
I think this user tries to something related to your question: Edge alignment in Boundary Layer y+ adaptation
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Generating elliptic grid around NACA SC2-0714 airfoil | DA6righthand | Main CFD Forum | 20 | November 3, 2015 08:50 |
Non-rigid node displacement using Dynamic mesh | mrestrepo30 | FLUENT | 3 | September 30, 2009 23:37 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
Hanging node grid + load balancing in parallel??? | Phil | FLUENT | 0 | February 15, 2008 09:38 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
