Why do the laplacian mesh motion solvers solve for the cell centres?
Old   May 1, 2020, 00:56
Default Why do the laplacian mesh motion solvers solve for the cell centres?
tecmul is on a distinguished road
In the displacementLaplacian and velocityLaplacian motion solvers, if I'm understanding the code correctly, the motion of the boundaries (provided by the user in the pointMotion file) is interpolated onto the centres of the boundary cells. Then the laplace equation equation is solved for the displacement/velocity of the cell centres. The new position of the mesh nodes is then interpolated from the cell centres. Is this correct? If it is, why not just directly solve for the displacements of the mesh nodes? Then you don't need to interpolate.
tecmul is offline   Reply With Quote
Old   May 4, 2020, 18:38
Michael@UW is on a distinguished road
Foam-extend does that using FEM. FVM solves the variables at the celk center.
Michael@UW is offline   Reply With Quote
Old   May 4, 2020, 18:57
That makes sense, thanks very much.
center, centre, mesh motion, moving mesh, velocitylaplacian
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 10:29
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
