"undefined reference to" problem with libraries
Old   April 24, 2020, 13:42
Default "undefined reference to" problem with libraries
Francesco95's Avatar
Francesco Latella
Francesco95 is on a distinguished road
Hi guys,
I'm translating a modified version of Interfoam by the OpenFOAM version 2.2.1 to the latest version OpenFOAM 7. When I try to compile the code I obtain errors about one of the libraries created for this new solver. In particular I obtain an "undefined reference to" here the message
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/ag600/OpenFOAM/OpenFOAM-7/src/transportModels/twoPhaseMixture/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/transportModels -I/home/ag600/OpenFOAM/ag600-7/src_myInterFoamVOFSmoothEvap7/interfaceProperties/lnInclude -I/home/ag600/OpenFOAM/ag600-7/src_myInterFoamVOFSmoothEvap7/twoPhaseProperties/lnInclude -I/home/ag600/OpenFOAM/ag600-7/src_myInterFoamVOFSmoothEvap7/twoPhaseMixture/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/transportModels/incompressible/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/transportModels/interfaceProperties/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/TurbulenceModels/incompressible/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/finiteVolume/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/dynamicFvMesh/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/meshTools/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/sampling/lnInclude -IlnInclude -I. -I/home/ag600/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude -I/home/ag600/OpenFOAM/OpenFOAM-7/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/myInterFoamVOFSmoothEvap7.o -L/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib \
	    -L/home/ag600/OpenFOAM/ag600-7/platforms/linux64GccDPInt32Opt/lib -lmyinterfaceProperties_VOFSmoothEvap -lmytwoPhaseProperties_VOFSmoothEvap -lmytwoPhaseProperties_VOFSmoothEvap -lmytwoPhaseMixture_VOFSmoothEvap -limmiscibleIncompressibleTwoPhaseMixture -lturbulenceModels -lincompressibleTurbulenceModels -lfiniteVolume -ldynamicFvMesh -ltopoChangerFvMesh -lfvOptions -lmeshTools -lOpenFOAM -ldl  \
	     -lm -o /home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/myInterFoamVOFSmoothEvap7
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::NamedEnum<Foam::UPstream::commsTypes, 3>::names'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::IOobject::headerOk()'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::Vector<double>::zero'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::TimeState::timeIndex() const'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::sumReduce(double&, int&, int)'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::regIOobject::write() const'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::regIOobject::readStream(Foam::word const&)'
/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libmyinterfaceProperties_VOFSmoothEvap.so: undefined reference to `Foam::Vector<double>::typeName'
collect2: error: ld returned 1 exit status
make: *** [/home/ag600/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/myInterFoamVOFSmoothEvap7] Error 1
my make/options file is this:
EXE_INC = \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(WM_PROJECT_USER_DIR)/src_myInterFoamVOFSmoothEvap7/interfaceProperties/lnInclude \
    -I$(WM_PROJECT_USER_DIR)/src_myInterFoamVOFSmoothEvap7/twoPhaseProperties/lnInclude \
    -I$(WM_PROJECT_USER_DIR)/src_myInterFoamVOFSmoothEvap7/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/dynamicFvMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lmyinterfaceProperties_VOFSmoothEvap \
    -lmytwoPhaseProperties_VOFSmoothEvap \
    -lmytwoPhaseMixture_VOFSmoothEvap \
    -limmiscibleIncompressibleTwoPhaseMixture \
    -lturbulenceModels \
    -lincompressibleTurbulenceModels \
    -lfiniteVolume \
    -ldynamicFvMesh \
    -ltopoChangerFvMesh \
    -lfvOptions \
    -lmeshTools
and as you see, I have in the file that library. I'm really new in the OF programming world, so if you could also explain me what I'm maybe doing wrong I will be very gratefull! I know that in this file i put the link for let the compilation able to find the libraries needed for the solver. And if I understand well when I compile I find the libraries, but seems that I have some problem with functions and classes inside these libraries right? So it means that they are in correct folder no? So what's the problem with these messages?
Thank you all in advance!
Francesco95 is offline   Reply With Quote
Old   April 27, 2020, 03:11
Yogesh Bapat
ybapat is on a distinguished road
Move part from FOAM_USER_LIBBIN to your libraries below OF libraries.
ybapat is offline   Reply With Quote
Old   April 27, 2020, 05:39
Francesco Latella
Hi Yogesh, thank you for the reply.
I have already did that. I have these libraries inside the folder $FOAM_USER_LIBBIN and inside the lib folder of OpenFOAM, and is not working
Old   April 27, 2020, 05:56
Francesco Latella
I'm thinking about that and I'm wondering if this "undefined reference to" error is due by the fact that this library is created by another person and is not an original one of OpenFOAM so I need first to compile her and only after do the wmake to the solver?
Old   April 27, 2020, 10:43
Francesco Latella
Hi guys, I tried removing the three libraries that gave me that "undefined reference to" error and now it compile! But this is something really strange that I'm not able to understand...I've just one explanation and please tell me if I'm wrong.
If the solver is compiled also without those libraries, it means that they are not needed by the solver, am I right? So, maybe, should work, no?
libraries, library, undefined reference, wmake error, wmake problems
[OpenFOAM.com] An Error in recompiling of openFoam-4.0 alimea OpenFOAM Installation 4 April 8, 2020 15:44
wmake problems during custom utility compilation palazi88 OpenFOAM Programming & Development 11 August 13, 2018 21:52
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Error in compiling new drag model k.farnagh OpenFOAM Programming & Development 13 May 21, 2016 04:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
