April 7, 2020, 00:09 |
pUcoupledFoam convergence problem
Liu Yang
Rep Power: 15 |
Hello everyone,
I tried pUcoupledFoam for simulation of laminar flow over a square cylinder for several days, but I can't obtain a converged solution. While simpleFoam works for the same case. Would someone please give me some instructions? I used foam-extend 4.1 in my test. My settings for the solver is like this: solvers { Up { solver AMG; cycle V-cycle; coarseningType AAMG; norm componentNorm; normComponent 0; nPreSweeps 4; nPostSweeps 4; groupSize 2; minCoarseEqns 4; nMaxLevels 10; scale on; smoother ILU; minIter 1; maxIter 500; tolerance 1e-9; relTol 0.0; } } Thank you. LiuYang |
April 11, 2020, 17:16 |
Herpes Free Engineer
Rep Power: 13 |
might be useful to report the problem to foam-extend. see the issue-reporting link below for the foam-extend issue tracker.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
convergence, pucoupledfoam |
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
