add a phase diffusion term in both continuity and monmentum equations for twoPhEuler |
February 6, 2020, 11:33 |
#21 |
It is so weird. When I used the mesh with larger boundary layer thickness, the result is reasonable and accurate. After I decreased the boundary layer thickness, it was crashed cause the bounding k and epsilon were infinite. Who can give me some suggestions? Thanks!
February 7, 2020, 04:22 |
#22 | |
Cyprien
Rep Power: 18 |
www.cypriensoulaine.com/openfoam |
February 7, 2020, 04:40 |
#23 | |
- fvc::div(fvc::grad(alpha1)*rho1*phase2.turbulence( ).nut()/sigma*U1) this code is reasonable or not? After I added this code in the equation, it can be compiled and run well for the corse mesh. However, when I use a lower thickness of boundary layer, the simulation crashed. |
February 7, 2020, 04:59 |
#24 |
-fvm::div(fvc::snGrad(alpha1)*mesh.magSf()*fvc::int erpolate(rho1*phase2.turbulence().nut())/sigma, U1)
I changed it to be like this, it compiled. But the simulation is also crashed for the fine boundary layer mesh. |
February 7, 2020, 05:23 |
#25 | |
Please help me to verify the codes I wrote are right or not? In Uequation I wrote like this: U1Eqn = ( fvm::div(alphaRhoPhi1, U1) - fvm::Sp(fvc::div(alphaRhoPhi1), U1) + MRF.DDt(alpha1*rho1, U1) + - fvm::laplacian(alpha1*rho1*phase2.turbulence().nuE ff(), U1) - fvc::div(fvc::grad(alpha1)*rho1*phase2.turbulence( ).nut()/sigma*U1) While in p equation I added one code in p equacomp1 and equacomp2: pEqnComp1 = ( contErr1 - fvc::Sp(fvc::ddt(alpha1) + fvc::div(alphaPhi1), rho1) )/rho1 + (alpha1*psi1/rho1)*correction(fvm::ddt(p_rgh)) - fvc::laplacian(phase2.turbulence().nut()/sigma,alpha1); |
February 9, 2020, 00:30 |
#26 |
Dongyue Li
Rep Power: 18 |
The equation looks not correct. Perhaps the first term should be a \nabla\cdot instead of \nabla. Meanwhile, 1) to add a diffusion term, you better to add that after MULES to ensure boundedness. See how it does in driftFluxFoam. 2) There is already a turbulent dispersion force in E-E model and it was implemented already, see "turbulent dispersion force". 3) The momentum interfacial exchange term needs to be addressed in UEqn, not pEqn. 4) div(grad()) employs an extended stencil instead of a compact stencil, which means it may introduce possible oscillations.
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
February 10, 2020, 04:37 |
#27 |
Thanks a lot Dongyue. The equations that I wrote here are not accurate and you are right.
We will not use the dispersion force defined in the openfoam because our group provided a new two fluid model that add two dispersion terms in both continuity and momentum equations which makes numerical stability and fast calculating. In terms of "div(grad()) employs an extended stencil instead of a compact stencil", how to solve the problem you mentioned. However we have to add the div(grad(alpha)) |
multiphaseflow, twophaseeulerfoam |
