OpenFOAM - Dakota coupling/Issues with Dakota parameters file |
February 4, 2020, 12:34 |
Rep Power: 6 |
I am looking to couple OpenFOAM with Dakota. I started with tutorials available in Wolf Dynamics. I have been working on the simple cavity gradient case. Here's the Dakota input file - environment tabular_data tabular_data_file = 'table_out.dat' method conmin_frcg max_iterations = 100 convergence_tolerance = 1e-4 max_function_evaluations = 20 variables continuous_design = 1 cdv_initial_point -1.8 cdv_lower_bounds -2.0 cdv_upper_bounds 3.0 cdv_descriptor 'x1' responses num_objective_functions = 1 numerical_gradients method_source dakota interval_type forward #fd_gradient_step_size = .000001 fd_gradient_step_size = 1.e-5 # to instead use analytic gradients returned by the simulator comment the # preceding two lines and uncomment the following: ## analytic_gradients no_hessians sense 'max' interface fork asynchronous #evaluation_concurrency = 4 evaluation_concurrency = 1 analysis_driver = 'OF_D.sh' parameters_file = 'params.in' results_file = 'results.out' work_directory directory_tag copy_files = 'templatedir/*' # uncomment to leave params.in and results.out files in work_dir subdirectories named 'workdir' file_save directory_save # when using conmin_frcg (above) with analytic_gradients (below), # need to turn off the active set vector When I run this file, I get the following error - /params.in: line 1: 1: command not found /params.in: line 2: -1.800000000000000e+00: command not found /params.in: line 3: 1: command not found /params.in: line 4: 1: command not found /params.in: line 5: 1: command not found /params.in: line 6: 1: command not found /params.in: line 7: 0: command not found /params.in: line 8: 1: command not found When I add the aprepro command to the following statement in the input file, # uncomment to leave params.in and results.out files in work_dir subdirectories named 'workdir' file_save directory_save aprepro Here's the error I get - /params.in: line 9: syntax error: unexpected end of file It seems like the issue is with the Dakota parameters file format. But I am not sure how to fix it. Thank you for any help you can provide! - Ilaj Last edited by ilaj; February 10, 2020 at 10:21. |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 | Yage | OpenFOAM Community Contributions | 18 | February 15, 2016 02:02 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
