fvOption ERROR in openFoamv7
Old   February 3, 2020, 05:59
Default fvOption ERROR in openFoamv7
divyesh's Avatar
Divyesh Variya
divyesh is on a distinguished road
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-1ff648926f77
Exec   : /opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/DiffusionVFoam
Date   : Feb 03 2020
Time   : 15:23:49
Host   : "fossee"
PID    : 6437
I/O    : uncollated
Case   : /home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: No convergence criteria found
Reading field T
Reading transportProperties
Reading diffusivity DT
Reading constant k
Reading field T
Creating finite volume options from "system/fvOptions"
Selecting finite volume options model type scalarCodedSource
    Source: source
    - selecting all cells
    - selected 50 cell(s) with volume 0.01
Using dynamicCode for fvOption:: source at line 26 in "/home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/system/fvOptions.source.scalarCodedSourceCoeffs"
Creating new library in "dynamicCode/source/platforms/linux64GccDPInt32Opt/lib/libsource_dfd5342987be824d3cd437c04f4e5f18ca2f43c7.so"
Invoking "wmake -s libso /home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/dynamicCode/source"
wmake libso /home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/dynamicCode/source
    ln: ./lnInclude
    wmkdep: codedFvOptionTemplate.C
    Ctoo: codedFvOptionTemplate.C
/home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/system/fvOptions.source.scalarCodedSourceCoeffs: In member function ‘virtual void Foam::fv::sourceFvOptionscalarSource::addSup(Foam::fvMatrix<double>&, Foam::label)’:
/home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/system/fvOptions.source.scalarCodedSourceCoeffs:48:39: error: no match for ‘operator-=’ (operand types are ‘double’ and ‘Foam::dimensionedScalar {aka Foam::dimensioned<double>}’)
/home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/system/fvOptions.source.scalarCodedSourceCoeffs: In member function ‘virtual void Foam::fv::sourceFvOptionscalarSource::addSup(const volScalarField&, Foam::fvMatrix<double>&, Foam::label)’:
/opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/codedFvOptionTemplate.o' failed
make: *** [Make/linux64GccDPInt32Opt/codedFvOptionTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/source/platforms/linux64GccDPInt32Opt/lib/libsource_dfd5342987be824d3cd437c04f4e5f18ca2f43c7.so"
file: /home/sathish/Desktop/Divyesh-FOSSEE/OpenFOAM_HT_Course/Conduction/Problem-3-1/system/fvOptions.source.scalarCodedSourceCoeffs from line 26 to line 54.
    From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
    in file db/dynamicLibrary/codedBase/codedBase.C at line 206.
FOAM exiting
I am trying to add a volumetric heatsource in laplacianFoam, when i run case this error appears. What are the issue?
divyesh is offline   Reply With Quote
Old   February 4, 2020, 00:27
Yogesh Bapat
ybapat is on a distinguished road
You are using codes source and operators which are not defined are being used. -= operator is used for scalar and dimensionedScalar.
ybapat is offline   Reply With Quote
Old   February 4, 2020, 01:38
divyesh's Avatar
Divyesh Variya
source
    type    scalarCodedSource;
    active    true;
    name    source;
        selectionMode    all;
        fields    (T);
    codeInclude
    codeCorrect
        Pout<< "**codeCorrect**" << endl;
 codeAddSup
    const Time& time = mesh().time();
    const vectorField& C = mesh().C();
    const scalarField& V = mesh_.V();
    scalarField& source = eqn.source();
             forAll(C, i)
                            source[i] -= (exp(time)*((sqr(C[i].x()))-2.0)*V[i]);
codeConstrain
        Pout<< "**codeConstrain**"<< endl;
This is my code for fvOptions.
Should I put = instead of -= ?
Divyesh Variya
Old   March 11, 2021, 09:51
Jonas
JonL is on a distinguished road
Hello divyesh, did you eventually end up finding a solution on how to implement a source term for your field T using fvOptions? I am currently trying to do the same thing (different term, but same metthod), but keep running into unsolved errors..
JonL is offline   Reply With Quote
Using fvOption file Raza Javed OpenFOAM Pre-Processing 3 April 17, 2019 12:02
How to Use fvoption file in our problem Raza Javed Main CFD Forum 0 April 12, 2019 06:01
Fvoption Raza Javed OpenFOAM Running, Solving & CFD 0 April 11, 2019 16:59
fvOption - pressureGradient gu1 OpenFOAM Pre-Processing 0 October 18, 2018 22:39
fvOption interpolation scheme aghsin OpenFOAM Running, Solving & CFD 0 June 25, 2016 10:01
