Check if a face center lies on a patch that is not being meshed |
January 31, 2020, 09:24 |
David Andersson
Rep Power: 7 |
Hi all,
I am simulating wind on a highrise building and I need to check if a face center lies on a patch that is not being meshed. I have a couple of .stl-files that describes my geometry and that I include in snappy for meshing. I need to assign a constant value to each face that I will use for further computations and I therefore thought I could provide a list that links each patch in a second set of stl-files (that also describes the complete geometry but by more and different files) with a constant value and check on which patch each of my meshed faces lie. The second set of stl's are NOT included in the snappyDict and hence not meshed, however they are found in the constant/triSurface directory. A bit tricky to explain my problem but I hope someone understands what it is I am trying to do and it would be great if someone could help me out here. Thanks, David |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 03:01 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
