Loop through a volScalarField
Old   January 30, 2020, 08:54
Default Loop through a volScalarField
anonymous
simrego is on a distinguished road
Hi!
I wrote a small total lagrangian solid displacement solver, and I'm trying to create material models for it. The material model is simply returns the Lame's coefficients, BUT. If I loop through the field in my update() function in my material model, the solver gives some weird results.
For example:
Simple bilinear model, I have let's call Ee_, and Ep_, and based on the strain and stress i set the E_ from Ee_ and Ep_. If i loop through the list and set like "E_[i] = Ee_[i];", the results are reallly bad. If i set "E_ = Ee_;" without loop, it's working perfectly.
I wrote out the E_ field for both case and the are exactly the same...
Anyone any ideas? I'm pretty lost now.
Thanks!
simrego is offline   Reply With Quote
Old   January 30, 2020, 09:43
Default Solved
anonymous
E_.correctBoundaryConditions(); did it. :S
Old   January 30, 2020, 10:17
Emad Tandis
EmadTandis is on a distinguished road
Originally Posted by simrego View Post
Hi!
For example:
Thanks!
I guess the difference is because for the loop case, you don't set boundaryFields but for E_=Ee_, not only cell field but also boundaries are set as well.
EmadTandis is offline   Reply With Quote
Old   January 30, 2020, 10:19
anonymous
Yep you are right. That was the problem.
Thx the feedback.
[Gmsh] Extrude on gmsh Pedro Felix OpenFOAM Meshing & Mesh Conversion 0 October 30, 2019 13:33
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 16:51
Error message Bruno_Jorge Main CFD Forum 1 February 5, 2019 12:12
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
