Running OpenFOAM case through shell script (bash)
Old   January 27, 2020, 18:46
Default Running OpenFOAM case through shell script (bash)
ilaj is on a distinguished road
I intend to run an OpenFOAM case through shell script. The example that I chose was lid driven cavity. Here's what I have done -
1. Open the terminal - cd case_directory_name
2. Create a shell script (shown below)
#!/bin/bash
blockMesh > log.blockmesh
icoFoam > log.icofoam
probeLocations -latestTime > log.probes
3. The shell script was saved in the case directory
4. In the same terminal, sudo sh file_name.sh
Here's the error I get -
blockMesh: not found
icoFoam: not found
probeLocations: not found
How should I proceed? Thank you for any suggestions you can provide.
- Ilaj
ilaj is offline   Reply With Quote
Old   January 28, 2020, 02:57
Andreas P.
AndreasPe is on a distinguished road
You maybe need to source your OpenFOAM environment in the terminal or in the script?
AndreasPe is offline   Reply With Quote
Old   January 28, 2020, 14:14
I tried the following based on your suggestion -
1. In CAE terminal, cd open_OpenFOAM_case_directory
2. sudo bash my_bash_script.sh
bash script had the following commands -
#!/bin/bash
source ~/openfoam6/etc/bashrc
This worked!
Thanks you!
- Ilaj
[OpenFOAM] Using python script for automatic post processing of openFoam vPaquet ParaView 12 December 16, 2021 04:30
Almost have my cluster running openfoam, but not quite... bjr OpenFOAM Running, Solving & CFD 17 March 6, 2020 10:52
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
