Overset implementation for heat transfer solvers using foam-extend-4.1
Old   January 19, 2020, 08:45
Default Overset implementation for heat transfer solvers using foam-extend-4.1
Mattia
time- is on a distinguished road
as per topic title, I was wondering if is possible to implement foam-extend overset capabilities into different solvers like buoyantSimpleFoam or rhoSimpleFoam.
I need to solve heat transfer for an internal flow case and I had good results with simpleOversetFoam despite interpolation errors. As I need to make a design study with different geometries, I'd like to make use of overset method to avoid remeshing, but foam-extend doesn't ship any heat transfer overset solvers.
Before going throu code editing, I just wanted to ask you if one of these solution may be doable:
1. To add overset to rhoSimpleFoam, following how it's implemented in incompressible solvers
2. To add overset to buoyantBoussinesqSimpleFoam (may be easier as it's incompressible?)
3. To add temperature equation to simpleOversetFoam (any ideas on this subject?)
Thanks
Mattia
time- is offline   Reply With Quote
Old   January 19, 2020, 08:57
Michael Alletto
mAlletto will become famous soon enough
In the openFoam.com version there is a compressible overset solver https://develop.openfoam.com/Develop...oPimpleDyMFoam
So you can find there some inspiration how to achieve things in the extend version
Best
Michael
mAlletto is offline   Reply With Quote
foam-extend 4.1, heat transfer, overset
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Data transfer between different foam solvers enoch OpenFOAM Post-Processing 1 March 16, 2012 03:32
