programming a subroutine inside the time loop
Old   January 14, 2020, 12:20
Default programming a subroutine inside the time loop
Felix Benz
FBenz is on a distinguished road
Dear OpenFoam Users,
I am trying to implement a subroutine inside the main time loop which looks something like:
while(runTime.loop())
solve first equation
while (some convergence criteria)
solve second equation
The solver compiles and the case is working, but it seems to be that openfoam does not like it if I call solve over and over again in the same time step.
If I run the two pieces of code:
1:
while (runTime.loop())
dU *= (0.0,0.0,0.0);
solve
fvm::laplacian(mu,dU) + fvc::div(sigma) //mu, dU and sigma are just dummy fields
prevTime = time;
time = runTime.elapsedCpuTime();
Info << "Time needed : " << time - prevTime << nl;
and
2:
while(true)
solve
prevTime = time;
time = runTime.elapsedCpuTime() ;
the first code will give me a constant "Time needed" as expected, while the second will increase with every iteration.
I guess runTime.loop() will kind of reset the field or the objectRegistry?
Is there a way to circumvent this problem or to access the registry manually?
Thanks in advance
Felix
FBenz is offline   Reply With Quote
run time, subroutine
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
