How to call sigmaK()?
Old   November 29, 2019, 08:48
Default How to call sigmaK()?
Elisabeth Diehl
elsebaer is on a distinguished road
Hello everybody,
instead of using mixture.surfaceTensionForce() on the right side of UEqn.H, I want to calculate a slightly different term "by hand".
Therefore, I took the implementation of the surfaceTensionForce and replaced just the second addend:
solve
    UEqn
    fvc::reconstruct
          + fvc::interpolate(interfaceProperties::sigmaK()) * ...
        ) * mesh.magSf()
It doesn't work, the following error occurs:
error: cannot call member function 'Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >Foam::interfaceProperties::sigmaK() const' without object
Calling sigmaK() with mixture.sigmaK() or interface.sigmaK() does not work too. Do you have another idea?
Thank you!
elsebaer is offline   Reply With Quote
Old   November 29, 2019, 09:49
Elisabeth Diehl
Ok, I found out that it works with fvc::interpolate(mixture.sigmaK()). No idea why it did not work 1000 times before
Any experts on FFTW? jinhua2015 Main CFD Forum 3 May 22, 2022 20:44
Compiling User Fortran with CFX 14.0 on Win64 Raijin Thunderkeg CFX 29 March 9, 2016 12:45
writing link between two CGNS files t.teschner Main CFD Forum 1 February 4, 2014 11:26
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 23:01
Who's ok for an Open Source CFD project ? Viet Main CFD Forum 16 July 26, 1999 16:57
