Divergence with solution variable as first entry
Old   November 22, 2019, 10:10
Question Divergence with solution variable as first entry
Elisabeth Diehl
elsebaer is on a distinguished road
Hi everybody,
I have to include the term div(rho * dU & U) in a fvVectorMatrix, where & denotes the inner product of dU and U. The equation shall be solved for dU. I implemented the following code:
surfaceScalarField dPhi
    IOobject
        "dPhi",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT,
        IOobject::AUTO_WRITE
    fvc::flux(dU)
surfaceScalarField rhoDPhi(fvc::interpolate(rho)*dPhi);
fvVectorMatrix dUEqn.H
  + fvm::div(rhoDPhi & U)
I didn't get an error while compilation, but when I want to solve a test case, I get the following error:
incompatible fields for operation [dU] + [U]
In my opinion, this results from the fact, that the term fvm::div(rhoDPhi & U) causes OpenFOAM to think that U is the solution variable of the system instead of dU.
Do you have an idea how to "switch" dU and U in a mathematically correct way, without writing a new divergence operator?
Thanks a lot for thinking about this!
elsebaer is offline   Reply With Quote
divergence
Compressible steady state solution divergence Nero_CMU OpenFOAM Running, Solving & CFD 5 January 12, 2016 10:57
how to get the divergence of a vector variable on a patch GP_FDU OpenFOAM Running, Solving & CFD 1 March 18, 2013 15:12
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Divergence detected in solution Kevan Moodley Main CFD Forum 7 June 28, 1999 09:12
