Changing boundary condition Ux after fluid reaches a specific distance
Old   November 19, 2019, 06:23
Default Changing boundary condition Ux after fluid reaches a specific distance
X
mcfdma is on a distinguished road
Hello. I am working on filling the capillary with fluid.
The flow rate (Ux) is slow and the capillary is long which results in taking significant amount of time to fill the entire capillary.
Is there a way to speed up this process by initially setting the Ux to be high (higher than the value needed for the case) and once it reaches a particular distance in x coordinate, the Ux value is reduced automatically without me stopping the case and manually reducing the Ux and re-running it.
I have been looking at codedFixedValue but not sure.
Any help?
mcfdma is offline   Reply With Quote
Old   November 19, 2019, 11:03
Hosein
einstein_zee is on a distinguished road
Hi there,
you may find this one useful How to correctly show the result of #codeStream# internalField?
einstein_zee is offline   Reply With Quote
Old   November 21, 2019, 04:52
raumpolizei is on a distinguished road
Hey
I don't know your specific case but this sounds like this could be estimated by hand. With codedFixedValue, you are on the right track. Based on what you wrote there are a few other options you may want to try out:
  1. GroovyBC - check if swak4foam is available for your OF version. You could prescribe a ramp for the inflow velocity.
  2. Also, depending on your domain, you may want to have a look at funkysetfields (also a swak4foam utility).
  3. This wont solve you problem but you could use a coarse mesh and run the case until you are reaching the state of interest. Or a bit before if the case is turbulent in order to allow turbulence to evolve. Map it to the fine mesh and continue your simulations (mapFields).
  4. Write a bash script for the whole case, including the velocity change (use foamDictionary and similar commands).
Good luck!
RP
raumpolizei is offline   Reply With Quote
capillary flow, interfoam
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
