Loop over face pressure values
Old   November 18, 2019, 08:36
Default Loop over face pressure values
David Andersson
sippanspojk is on a distinguished road
Hi all,
I am writing my own functionObject where I want to loop over each face in a specified patch and do some computations on the pressure values.
I generated a new file with foamNewFunctionObject. Then I found online the following code snippet that is almost doing what I want:
const polyBoundaryMesh& boundaryMesh = mesh.boundaryMesh();             // Boundary mesh
forAll(mesh.boundary(), patch)
    const word& patchName = mesh.boundary()[patch].name();              // Boundary patch name
    forAll(mesh.boundary()[patch], facei)
        const label& face = boundaryMesh[patch].start() + facei;        // FaceID
I would like to add a new variable myPressureField and extract the pressure value in the center of each face in the inner loop. Somthing like this:
const surfaceScalarField& myPressureField = p.boundaryMesh();
        const scalar& faceP = myPressureField[patch][facei]
I am new to programming in OpenFOAM so I am more or less guessing how I should do it based on what I can find online.
I would be thankful for some guidance with this.
Cheers,
David
sippanspojk is offline   Reply With Quote
Old   November 19, 2019, 01:09
clapointe is on a distinguished road
Here's a bit of code I've used in the past for T values on a patch -- changing for p should be trivial.
    const volScalarField& Temp = mesh().lookupObject<volScalarField>("T");
    Foam::label patchLabel = mesh().boundaryMesh().findPatchID("myName");
    const Foam::fvPatch& patch = mesh().boundary()[patchLabel];
    forAll(currPatch,facei)
        Foam::label faceCelli = currPatch.faceCells()[facei];
        Foam::scalar Tempi = Temp[faceCelli];
Caelan
clapointe is offline   Reply With Quote
Old   November 19, 2019, 03:21
David Andersson
Thank you Caelan for your answer!
Am I right when I say I should define this directly in my .C file?
At the moment I am just trying out the first row where I define my field, like this:
    const volScalarField& myPressure= mesh_.lookupObject<volScalarField>("p");
and it doesn't work. I also tried with volVectorFiled and "U" but the same problem.
Do I need to #include some special library(ies) to be able to access the fields?
//David
Old   November 19, 2019, 11:40
Yes, it'll go in the .C file for your function object.
Caelan
Old   November 19, 2019, 11:56
David Andersson
I finally got it to work when I included "fvcGrad.H". Does that make sense? What is in that library?
Old   November 19, 2019, 12:09
Ultimately you'd need to link in something like fvCFD.H, which most function objects would do (I hope you didn't start from scratch, and copied an existing function object to work from!). That said, while the code I pasted doesn't need fvcGrad.H, it might need something that the .H file loops in. It is used to compute gradients of a volume field. Without seeing the compilation error it is hard to tell.
Caelan
Old   June 13, 2024, 08:03
Klaus
klausb will become famous soon enough
@sippanspojk
Would you please share your implementation?
klausb is offline   Reply With Quote
pressure field, programming
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
