undefined symbol error
Old   November 7, 2019, 07:42
Default undefined symbol error
Ian
insane is on a distinguished road
Hi everyone
Recently, I developed a new class named ControllerStateProvider in the src fold and use the allwmake to compile it and there is no error.
After that, I modify the rigidbodyState (a function object to get the state of moving body) and add several lines about the ControllerStateProvider class , and I have modify the option of the rigidbodyState, just like this
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/dynamicMesh/lnInclude \
    -I$(LIB_SRC)/dynamicFvMesh/lnInclude \
    -I$(LIB_SRC)/ControllerStateProvider/lnInclude \
    -I$(LIB_SRC)/rigidBodyDynamics/lnInclude \
    -I$(LIB_SRC)/rigidBodyMeshMotion/lnInclude \
    -I$(LIB_SRC)/OpenFOAM/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -L $(FOAM_LIBBIN) \
    -L $(FOAM_USER_LIBBIN) \
    -lControllerStateProvider \
    -ldynamicFvMesh \
I also include the ControllerStateProvider.H in the rigidbodyState.C and rigidbodyState could be successfully compiled.
but when I run a test case which use the interDyMFoam, it shows warning just like this
--> FOAM Warning :
    From function void* Foam::dlOpen(const Foam::fileName&, bool)
    in file POSIX.C at line 1604
    dlopen error : /home/ian/OpenFOAM/ian-v1712/platforms/linux64GccDPInt32Opt/lib/librigidBodyState.so: undefined symbol: _ZN4Foam23ControllerStateProvider8positionE
--> FOAM Warning :
    From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105
    could not load "librigidBodyState.so"
--> FOAM Warning :
    From function bool Foam::dlLibraryTable::open(const Foam::dictionary&, const Foam::word&, const TablePtr&) [with TablePtr = Foam::HashTable<Foam::autoPtr<Foam::functionObject> (*)(const Foam::word&, const Foam::Time&, const Foam::dictionary&), Foam::word, Foam::string::hash>*]
    in file lnInclude/dlLibraryTableTemplates.C at line 62
    Could not open library "librigidBodyState.so"
It's clear that the function object could not work, I am sure it works before the modification of rigidbodyState. And I have read several threads similar to this error which said it can be fixed by adding the corresponding lib in the option, but i have already added ControllerStateProvider in the option file .
Could anyone offer some advice? It will be much appreciated!
insane is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
