November 7, 2019, 01:57 |
aeroacoustic solver compilation error
Brett
Rep Power: 14 |
Hi all,
I've been following the Chalmers paper on implementing an aeroacoustic solver. I'm getting close but I come up with this error. Anyone have any ideas??? g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/cfdTools -I/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/sampling/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/transportModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/TurbulenceModels/compressible/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c rhoPimpleAdiabaticAcousticFoam.C -o /opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/compressible/rhoPimpleAdiabaticAcousticFoam/rhoPimpleAdiabaticAcousticFoam.o In file included from ./createFields.H:1:0, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/postProcess.H:133, from rhoPimpleAdiabaticAcousticFoam.C:68: /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H: In function ‘int main(int, char**)’: /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H:1:16: error: ‘Foam::fv::localEulerDdt’ has not been declared bool LTS = fv::localEulerDdt::enabled(mesh); ^~~~~~~~~~~~~ /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H:15:17: error: ‘localEulerDdt’ is not a member of ‘Foam::fv’ fv::localEulerDdt::rDeltaTName, ^~ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/postProcess.H:133:0, from rhoPimpleAdiabaticAcousticFoam.C:68: ./createFields.H:105:36: error: ‘dimensionsScalar’ was not declared in this scope dimensionsScalar(p.dimensions()) ^ ./createFields.H:188:1: warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations] ); ^ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.H:534:0, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedScalar.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/TimeState.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/Time.H:49, from /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/fvCFD.H:6, from rhoPimpleAdiabaticAcousticFoam.C:47: /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.C:258:1: note: declared here Foam::dimensioned<Type>::dimensioned ^~~~ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/postProcess.H:133:0, from rhoPimpleAdiabaticAcousticFoam.C:68: ./createFields.H:195:1: warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations] ); ^ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.H:534:0, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedScalar.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/TimeState.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/Time.H:49, from /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/fvCFD.H:6, from rhoPimpleAdiabaticAcousticFoam.C:47: /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.C:258:1: note: declared here Foam::dimensioned<Type>::dimensioned ^~~~ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/postProcess.H:133:0, from rhoPimpleAdiabaticAcousticFoam.C:68: ./createFields.H:165:8: warning: unused variable ‘timeIndex’ [-Wunused-variable] scalar timeIndex = 1; ^~~~~~~~~ In file included from createFields.H:1:0, from rhoPimpleAdiabaticAcousticFoam.C:77: /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H:1:16: error: ‘Foam::fv::localEulerDdt’ has not been declared bool LTS = fv::localEulerDdt::enabled(mesh); ^~~~~~~~~~~~~ /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H:15:17: error: ‘localEulerDdt’ is not a member of ‘Foam::fv’ fv::localEulerDdt::rDeltaTName, ^~ In file included from rhoPimpleAdiabaticAcousticFoam.C:77:0: createFields.H:105:36: error: ‘dimensionsScalar’ was not declared in this scope dimensionsScalar(p.dimensions()) ^ createFields.H:188:1: warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations] ); ^ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.H:534:0, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedScalar.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/TimeState.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/Time.H:49, from /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/fvCFD.H:6, from rhoPimpleAdiabaticAcousticFoam.C:47: /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.C:258:1: note: declared here Foam::dimensioned<Type>::dimensioned ^~~~ In file included from rhoPimpleAdiabaticAcousticFoam.C:77:0: createFields.H:195:1: warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations] ); ^ In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.H:534:0, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedScalar.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/TimeState.H:40, from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/Time.H:49, from /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/fvCFD.H:6, from rhoPimpleAdiabaticAcousticFoam.C:47: /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.C:258:1: note: declared here Foam::dimensioned<Type>::dimensioned ^~~~ In file included from rhoPimpleAdiabaticAcousticFoam.C:78:0: /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createFvOptions.H:1:37: error: redeclaration of ‘Foam::fv:ptions& fvOptions’ fv:ptions& fvOptions(fv:ptions::New(mesh)); ^~~ In file included from createFields.H:207:0, from rhoPimpleAdiabaticAcousticFoam.C:77: /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createFvOptions.H:1:14: note: ‘Foam::fv:ptions& fvOptions’ previously declared here fv:ptions& fvOptions(fv:ptions::New(mesh)); ^~~~~~~~~ In file included from rhoPimpleAdiabaticAcousticFoam.C:124:0: acousticSolver.H:4:16: warning: suggest parentheses around assignment used as truth value [-Wparentheses] if(timeIndex=1) ^ /opt/OpenFOAM/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target '/opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/compressible/rhoPimpleAdiabaticAcousticFoam/rhoPimpleAdiabaticAcousticFoam.o' failed make: *** [/opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/compressible/rhoPimpleAdiabaticAcousticFoam/rhoPimpleAdiabaticAcousticFoam.o] Error 1 |
November 21, 2023, 04:53 |
FOAMraj
Rep Power: 5 |
Did you figure out the issue? I am also getting same error in v2112. |
error during compilation of new solver | harsha_kulkarni | OpenFOAM Programming & Development | 2 | November 7, 2019 01:47 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
