XinZhou
Rep Power: 8 ![]() |
I am simulating a water droplet impact surface under electrical field based on the interFoamEHD solver which designed by ivook.My model is 2D-Axisymmetric. I find that the charge density distribution is weird, there is some charge appearing above the droplet along the axis. I am puzzled by this problem. The charge density distribution is related to the velocity Magnitude.
I think the charge conversation equation is calculated for all computation field,both water and air. However, for water, it will get polarized and ohmic migration of charged ions. For air,it can be regarded as a perfect dielectric, there is no charge convection.Gauss law should be I think we should use different physical model for water and air. But can it be realized in openfoam. I am comfused by the interfoam solver. How does this sovler distinguish the phase1 and phase2? I am reading the twoPhaseMixture.H, incompressibleTwoPhaseMiture.H ,but still get stuck.Could you please give me some advices? Last edited by XinXin; October 31, 2019 at 07:51. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
initialize open channel flow with a know water surface profile | Ema40 | Fluent Multiphase | 4 | February 21, 2016 11:31 |
Free water jet impinging hot solid surface, including boiling | hamdy | Fluent UDF and Scheme Programming | 5 | August 19, 2012 19:52 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
