Access phase fraction field in a phase change model
Old   October 17, 2019, 06:03
Default Access phase fraction field in a phase change model
Hendrik
hend is on a distinguished road
Hey,
this issue is about a multiphase simulation. I modified the reactingParcelFoam solver for for the phase change from particles/parcels to a specie of the carrier phase. Therefore I am using a phaseChange model related to the LiquidEvaporation model. Now this model should be extended by a phase fraction volume field generated in a beforehand simulation (interFoam). The phase transfer must be limited to one phase of the alpha field. For that, the alpha volScalarField is read in createFields initially.
Now my question: How can I acces the alpha phase fraction in the ReactingParcel class, which calls the the phase change model in a computational efficient manner?
Thanks in advance!
hend is offline   Reply With Quote
Custom Lagrangian Phase Change Model craven.brent OpenFOAM Programming & Development 4 December 25, 2022 20:22
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) remidemol OpenFOAM Running, Solving & CFD 3 May 26, 2020 06:47
Transient Phase Change Model: Explodes at low vapor quality evcelica CFX 0 August 28, 2018 11:55
use mixture model to simulate two-phase flow with phase change dxm2008 Fluent Multiphase 5 September 7, 2016 15:15
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
