error with compiling
Old   October 16, 2019, 13:52
Default error with compiling
hui cheng
chenghui62000 is on a distinguished road
Dear all,
I am trying to compile a solver from OF301 to OF1812 and encountered an error in the code.
The error are like that:
multiStepNetPorosityZone/multiStepNetPorosityZone.C: In member function ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::multiStepNetPorosityZone::ddt(Foam::volScalarField&, Foam::volVectorField&) const’:
multiStepNetPorosityZone/multiStepNetPorosityZone.C:202:19: error: binding reference of type ‘Foam::fvVectorMatrix& {aka Foam::fvMatrix<Foam::Vector<double> >&}’ to ‘const Foam::fvMatrix<Foam::Vector<double> >’ discards qualifiers
     modifyddt(tres());
multiStepNetPorosityZone/multiStepNetPorosityZone.C:51:6: note:   initializing argument 1 of ‘void Foam::multiStepNetPorosityZone::modifyddt(Foam::fvVectorMatrix&) const’
 void Foam::multiStepNetPorosityZone::modifyddt(fvVectorMatrix& m) const
/opt/OpenFOAM/OpenFOAM-v1812/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/multiStepNetPorosityZone/multiStepNetPorosityZone.o' failed
The relevant source code is liked:
//- modify ddt term
    const labelList& cells = mesh_.cellZones()[porosityZoneID_];
    const scalar coeff((1.0+addedMassCoeff_*(1-porosity_)/porosity_)/porosity_);
    forAll(cells, i)
        m.diag()[cells[i]]   *= coeff;
        m.source()[cells[i]] *= coeff;
Foam::tmp<Foam::fvVectorMatrix>
Foam::multiStepNetPorosityZone::ddt(volScalarField& rho, volVectorField& U) const
    tmp<fvVectorMatrix> tres = fvm::ddt(rho,U);
    modifyddt(tres());
    return tres;
Could anyone help me with that?
chenghui62000 is offline   Reply With Quote
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 08:30
Getting error both interpreting and compiling serene6390 Fluent UDF and Scheme Programming 1 October 27, 2017 01:49
All files present. but solver not compiling saddy OpenFOAM Programming & Development 1 July 29, 2017 10:50
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 15:03
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
