Different "starting conditions" for different materials (solids4Foam)
Old   August 14, 2019, 09:20
Default Different "starting conditions" for different materials (solids4Foam)
Bitte wählen
Tshiro is on a distinguished road
Hey Everyone,
I am currently trying to simulate the deformation of a bilayer beam where the 2nd layer is added not at the start of the simulation but at some later point
where the first one is already deformed. At that point the 2nd layer should be stress free while the first one has stress due to the deformation.
Right now I would try to set the material properties of the 2nd material basically to vacuum until I switch it on and then try to somehow set the deformation
in the 2nd layer as its initial undeformed state.
Do you know if this could work or there is an easier way to do this?
Tshiro is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Adding material to CFX material library marlon CFX 2 October 16, 2016 10:33
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
