some modification about the utility "setWave"
Old   July 31, 2019, 15:43
Default some modification about the utility "setWave"
ChengzhaoZhang
chengzhao is on a distinguished road
Dear everyone,
Currently I have been struggling with that how to apply the mean flow velocity only in the water phase for the wave simulation (can be linked to the tutorial "openFOAM6-tutorials/multiphase/interFoam/wave"). I used the utility called setWaves to set the date into field. In general, this utility reads and set the mean flow velocity in the entire domain including the air phase and water phase. My problem is that I only want to add the mean flow velocity in the water region (also called current velocity). However, this "setWaves" utility always add the unwanted air velocity by setting the keyword "Umean".
Therefore, I tried to modify the utility "setWaves" in order to let it only add the velocity "Umean" in the water phase. Does anyone have some ideas about how to separate the alpha phases and only add Umean to water phase? I am a beginner of programming,i am appreciated if anyone could give some advice.
Best wishes
The code can be seen as follow:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Copyright (C) 2017-2018 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
Application
setWaves
Description
Applies wave models to the entire domain for case initialisation using
level sets for second-order accuracy.
#include "fvCFD.H"
#include "levelSet.H"
#include "pointFields.H"
#include "timeSelector.H"
#include "wallDist.H"
#include "waveAlphaFvPatchScalarField.H"
#include "waveVelocityFvPatchVectorField.H"
#include "waveSuperposition.H"
int main(int argc, char *argv[])
timeSelector::addOptions(false, false);
Foam::argList::addOption
"U",
"name",
"name of the velocity field, default is "U""
"alpha",
"name",
"name of the volume fraction field, default is "alpha""
#include "setRootCase.H"
#include "createTime.H"
instantList timeDirs = timeSelector::selectIfPresent(runTime, args);
#include "createMesh.H"
#include "readGravitationalAcceleration.H"
const pointMesh& pMesh = pointMesh::New(mesh);
forAll(timeDirs, timeI)
runTime.setTime(timeDirs[timeI], timeI);
const scalar t = runTime.value();
Info<< "Time = " << runTime.timeName() << nl << endl;
mesh.readUpdate();
// Read the fields which are to be set
volScalarField alpha
IOobject
args.optionFound("alpha") ? args["alpha"] : "alpha",
runTime.timeName(),
mesh,
IOobject::MUST_READ
mesh
volVectorField U
IOobject
args.optionFound("U") ? args["U"] : "U",
runTime.timeName(),
mesh,
IOobject::MUST_READ
mesh
// Create modelled fields on both cells and points
volScalarField h
IOobject("h", runTime.timeName(), mesh),
mesh,
dimensionedScalar("0", dimLength, 0)
pointScalarField hp
IOobject("hp", runTime.timeName(), mesh),
pMesh,
volVectorField uGas
IOobject("uGas", runTime.timeName(), mesh),
mesh,
dimensionedVector("0", dimVelocity, vector::zero)
pointVectorField uGasp
IOobject("uGasp", runTime.timeName(), mesh),
pMesh,
dimensionedVector("0", dimLength, vector::zero)
volVectorField uLiq
IOobject("uLiq", runTime.timeName(), mesh),
mesh,
pointVectorField uLiqp
IOobject("uLiqp", runTime.timeName(), mesh),
pMesh,
// The number of wave patches
label nWaves = 0;
// Whether the alpha conditions refer to the liquid phase
bool liquid = false;
// Loop the patches, averaging and superimposing wave model data
forAll(mesh.boundary(), patchi)
fvPatchScalarField& alphap = alpha.boundaryFieldRef()[patchi];
fvPatchVectorField& Up = U.boundaryFieldRef()[patchi];
const bool isWave = isA<waveAlphaFvPatchScalarField>(alphap);
if (isA<waveVelocityFvPatchVectorField>(Up) != isWave)
FatalErrorInFunction
<< "The alpha condition on patch " << Up.patch().name()
<< " is " << alphap.type() << " and the velocity condition"
<< " is " << Up.type() << ". Wave boundary conditions must"
<< " be set in pairs. If the alpha condition is "
<< waveAlphaFvPatchScalarField::typeName
<< " then the velocity condition must be "
<< waveVelocityFvPatchVectorField::typeName
<< " and vice-versa." << exit(FatalError);
if (!isWave)
continue;
Info<< "Adding waves from patch " << Up.patch().name() << endl;
const waveSuperposition& waves =
refCast<waveVelocityFvPatchVectorField>(Up).waves( );
const bool liquidp =
refCast<waveAlphaFvPatchScalarField>(alphap).liqui d();
if (nWaves > 0 && liquidp != liquid)
<< "All " << waveAlphaFvPatchScalarField::typeName
<< "patch fields must be configured for the same phase,"
<< " i.e., the liquid switch must have the same value."
liquid = liquidp;
const pointField& ccs = mesh.cellCentres();
const pointField& pts = mesh.points();
// Internal field superposition
h.primitiveFieldRef() += waves.height(t, ccs);
hp.primitiveFieldRef() += waves.height(t, pts);
uGas.primitiveFieldRef() += waves.UGas(t, ccs) - waves.UMean(t);
uGasp.primitiveFieldRef() += waves.UGas(t, pts) - waves.UMean(t);
uLiq.primitiveFieldRef() += waves.ULiquid(t, ccs) - waves.UMean(t);
uLiqp.primitiveFieldRef() += waves.ULiquid(t, pts) - waves.UMean(t);
// Boundary field superposition
forAll(mesh.boundary(), patchj)
const pointField& fcs = mesh.boundary()[patchj].Cf();
h.boundaryFieldRef()[patchj] += waves.height(t, fcs);
uGas.boundaryFieldRef()[patchj] +=
waves.UGas(t, fcs) - waves.UMean(t);
uLiq.boundaryFieldRef()[patchj] +=
waves.ULiquid(t, fcs) - waves.UMean(t);
++ nWaves;
// Create the mean velocity field
volVectorField UMean
IOobject("UMean", runTime.timeName(), mesh),
mesh,
dimensionedVector("UMean", dimVelocity, Zero)
if (nWaves == 0)
// Warn and skip to the next time if there are no wave patches
WarningInFunction
<< "No " << waveAlphaFvPatchScalarField::typeName << " or "
<< waveVelocityFvPatchVectorField::typeName << " patch fields "
<< "were found. No waves have been set." << endl;
continue;
else if (nWaves == 1)
// Set a mean velocity equal to that on the only wave patch
const fvPatchVectorField& Up = U.boundaryField()[patchi];
if (!isA<waveVelocityFvPatchVectorField>(Up))
continue;
refCast<const waveVelocityFvPatchVectorField>(Up).waves();
UMean ==
dimensionedVector("UMean", dimVelocity, waves.UMean(t));
else if (nWaves > 1)
// Set the mean velocity by distance weighting from the wave patches
// Create weighted average fields for the mean velocity
volScalarField weight
IOobject("weight", runTime.timeName(), mesh),
mesh,
dimensionedScalar("0", dimless/dimLength, 0)
volVectorField weightUMean
IOobject("weightUMean", runTime.timeName(), mesh),
mesh,
dimensionedVector("0", dimVelocity/dimLength, vector::zero)
// Loop the patches, inverse-distance weighting the mean velocities
continue;
const volScalarField w
1
wallDist(mesh, labelList(1, patchi)).y()
+ dimensionedScalar("ySmall", dimLength, small)
weight += w;
weightUMean +=
w*dimensionedVector("wUMean", dimVelocity, waves.UMean(t));
// Complete the average for the mean velocity
UMean = weightUMean/weight;
// Set the fields
alpha == levelSetFraction(h, hp, !liquid);
U == UMean + levelSetAverage(h, hp, uGas, uGasp, uLiq, uLiqp);
// Set the boundary fields
if (isA<waveAlphaFvPatchScalarField>(alphap))
alphap == refCast<waveAlphaFvPatchScalarField>(alphap).alpha ();
Up == refCast<waveVelocityFvPatchVectorField>(Up).U();
// Output
Info<< "Writing " << alpha.name() << nl;
alpha.write();
Info<< "Writing " << U.name() << nl << endl;
U.write();
Info<< "End\n" << endl;
return 0;
chengzhao is offline   Reply With Quote
Old   August 3, 2019, 13:32
anon_q is on a distinguished road
Could you please format your post to add your program to code section.
anon_q is offline   Reply With Quote
Old   August 9, 2019, 12:29
ChengzhaoZhang
Hi Evren,
Thanks for taking the interest of the topic. My problem about this is solved. I didnot change the code. Just changed the internalfield date manually.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Noise postprocessing utility setup RFlamm OpenFOAM Post-Processing 5 July 30, 2018 11:06
wallHeatFlux Calculation wrt utility version ahmet OpenFOAM Post-Processing 1 December 18, 2016 20:45
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 17:47
Modification of collapseEdges utility olwi OpenFOAM Bugs 0 September 9, 2008 09:35
