Filipe Dias
Rep Power: 7 ![]() |
Hello everyone!
I have recently noticed that my cases suddenly lost processor independency, i.e., the processor separations now affect the results. After some digging, I tracked it to an operation I have when updating the energy equation boundaryField. In it I have: rhoE.boundaryField=(...)+rhoYh0.boundaryField(); In which rhoY0=rhoY1*h01+rhoy2*h02... Where h01 is the formation enthalpy for species 1. I tried to change the boundary update into: rhoE.boundaryField=(...)+rhoY1.boundaryField()*h01 +rhoy2.boundaryField()*h02... But when I compile, I receive an error stating that the operator * is not available between a geometricField and a dimensionedScalar. This only happens for the boundaryField, when updating the internalField this error does not appear. I want to ask if there is a way that I can perform this operation. Thank you kindly for your help |
Hosein
Rep Power: 14 ![]() |
hey,
have you tried to multiply it with ds.value()? [ds = dimensionedScalar] |
Filipe Dias
Good morning
That did work, thank you so very much!! By the way, has anyone ever had problem with parallel independence due to boundary condition and internalField update? Thank you very much for your help |
boundaryfield, openfoam 2.1.1 |
Temperature calculation from total enthalpy in OpenFOAM (XiFOAM) | sharifi | OpenFOAM Running, Solving & CFD | 1 | October 8, 2020 09:16 |
Problem about Rotor simulation whit high rotating speed | Thomas pan | OpenFOAM Running, Solving & CFD | 4 | June 20, 2018 06:24 |
error in fireFoam, when running the case wallFireSpread2D | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 9 | February 1, 2018 18:45 |
problem with total enthalpy solved by rhoporousmrfsimplefoam | mump0 | OpenFOAM Running, Solving & CFD | 3 | January 28, 2013 02:06 |
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls | david39 | OpenFOAM Running, Solving & CFD | 6 | January 18, 2011 11:49 |
