siavash
Rep Power: 7 ![]() |
I am new to OpenFOAM. I am trying to implement the attached energy equation for developing a solver to simulate evaporation. I was wondering if anyone could point me in the right direction and guiding me on how to implement this? I will be modifying interPhaseChangeFoam, I have created the required temperature field, and I have modified the mass transfer module. Thank you, Siavash |
hari charan
Rep Power: 4 ![]() |
Hello siavash,
Even I am trying the same. I implemented TEqn and required mass transfer model. but endded up with the errors like this. createFields.H:50: undefined reference to `Foam: ![]() /usr/bin/ld.bfd: /home/hari/OpenFOAM/hari-8/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleTwoPhaseThermalMixture.so: undefined reference to `Foam::conductivityModel::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&)' Have you solved your problem? If so can you tell me what I should do to remove the above Error |
siavash
Hey, yeah, I figured it out. It’s a lot more complicated. I am actually working on publishing my paper on it. If you give me a few weeks, I can share my solver with you and you can use it to modify whatever you want with it.
Mass transfer in interFoam is tricky because it happens at the interface, and you have to define a way to get gradient of vapor at interface. |
hari charan
Thanks for reply. Can you send me after publishing. I will try my best to resolve it mean while
energy equation, evaporation, new solver |
Porous Modeling of Energy equation in OpenFOAM | mohammad_kordo | OpenFOAM Running, Solving & CFD | 9 | November 22, 2020 07:18 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Source term energy equation for reactive flows | DaIN | Main CFD Forum | 0 | October 6, 2011 15:11 |
Viscosity and the Energy Equation | Rich | Main CFD Forum | 0 | December 16, 2009 14:01 |
question about energy equation | zhou | FLUENT | 0 | February 23, 2004 23:55 |
