Example of sending a struct over a Pstream?
Old   July 22, 2019, 16:07
Default Example of sending a struct over a Pstream?
Gavin Ridley
gridley2 is on a distinguished road
Hi all,
I am working on a solver where I have some structs (just a few pieces of data, about 5 integers and a handful of booleans) that sometimes need to be sent across processor boundaries. It's being used to track whether cells are in the vicinity of the liquid/gas interface in VOF calculations.
Can anyone point me to an example of sending a new struct or class using Pstreams? From what I have gathered, you just need to defined a operator>> and operator<< for the IPStream and OPstreams, but I seem to have made a mistake in doing this.
In particular, I'm confused about the order that stuff in the struct should be packed and unpacked into the Pstream. I can provide an example of what my current code looks like if needed. The specific error which arises is a segfault.
gridley2 is offline   Reply With Quote
Old   July 23, 2019, 12:03
Gavin Ridley
For anyone else who encounters an issue with this, the solution is to make something look like this:
struct ProcessorRequest
    label swagLevel;
    label originalProcessor;
    label neighborProcessor;
    Pair<bool> result;
    bool done;
Ostream& operator<<(Ostream& os, const ProcessorRequest& pr)
    os << pr.swagLevel;
     << pr.originalProcessor;
     << pr.neighborProcessor;
     << pr.result;
     << pr.done;
    return os;
Istream& operator>>(Istream& is, ProcessorRequest& me)
    is >> me.swagLevel
        >> me.originalProcessor
        >> me.neighborProcessor
        >> me.depth
        >> me.result
        >> me.done;
    return is;
Then it will go through Pstreams just like any other OpenFOAM primitive.
pstream library, pstreams
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 04:05
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
Sending a large bufffer between processes (with Pstream?) knuckles OpenFOAM Programming & Development 4 January 11, 2016 20:55
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
[Netgen] Compiling Netgen on Fedora Core is driving me crazy jango OpenFOAM Meshing & Mesh Conversion 3 November 9, 2007 14:29
