boundaryField() and internalField() While calculating heat flux
Old   July 13, 2019, 07:44
Default boundaryField() and internalField() While calculating heat flux
Ümit Yelken
uyelken is on a distinguished road
Hello my friends,
Im working to calculate heat flux on patch. I need to calculate reynolds number. But because of no slip bc applied on wall i must use internal value of velocity. Do you have any idea?
My code block is:
forAll(heatFlux.boundaryField(), patchi)
heatFlux.boundaryField()[patchi] =
k_mean.boundaryField()[patchi]*((0.024)*pow((rho.boundaryField()[patchi]*mag(U.internalField()[patchi])*(0.15)/nu_mean.boundaryField()[patchi]),0.8))*(0.898/(0.15))*(T.internalField()[patchi]-T.boundaryField()[patchi]);
It is not working. So how can i obtain internal field value?
uyelken is offline   Reply With Quote
Old   July 15, 2019, 11:19
Emily
em17 is on a distinguished road
To find the internal velocity of a cell adjacent to a patch you can use
U.boundaryField()[patchID].internalField()[internalCellID]
where 'patchID' is the ID of your patch and 'internalCellID' is the ID of the cell adjacent to the patch face.
You will then have to put this in a forAll loop to cycle through all the mesh cells on the patch face.
I hope this helps!
Emily
em17 is offline   Reply With Quote
Used Heat Flux instead of tempearture roshanak878 OpenFOAM 1 August 9, 2023 22:57
wallHeatFlux utility for an incompressible case Mr.Jingles OpenFOAM Post-Processing 67 April 6, 2023 04:25
ill defined primitiveEntry starting at keyword 'value' on line 197 ChangeDictionary Struggle_Achieve OpenFOAM Pre-Processing 2 December 20, 2017 04:58
solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam maddalena OpenFOAM Running, Solving & CFD 43 January 11, 2011 03:39
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 05:53
