volScalarMatrix adding and subtracting
Old   July 12, 2019, 13:35
Default volScalarMatrix adding and subtracting
Filipe Dias
FilipeDias93 is on a distinguished road
Good afternoon!
I have a question about the usage of the -= command in implementing in volScalarMatrix.
For example, consider the species continuity equation:
ddt(rho)+div(rho*U)+div(J)=w
So, starting by defining the Matrix with the convective terms:
fvScalarMatrix rhoYEqn
(fvm::ddt(rhoY)+fvc::div(rho*U));
Then to add the diffusive term:
rhoYeqn+= fvc::div(J);
And, finally, the source term:
rhoYeqn-= w;
I copied this from another code, and haven't been able to find it elsewhere. The code is also fairly complex, and I can't compare the equations.
My question is this: are the signs on the diffusive and source term correct?
Thank you kindly for your help
FilipeDias93 is offline   Reply With Quote
Old   July 14, 2019, 09:34
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Seems like everything is fine here. Moreover you can replace
rhoYeqn-= w;
with
rhoYeqn == w;
to state explicitly that your source tern goes to the right hand side.
Zeppo is offline   Reply With Quote
Old   July 14, 2019, 19:51
Filipe Dias
Thank you for your help. Is there any page with these kinds of information?
Old   July 19, 2019, 15:01
Zeppo's Avatar
Sergei
Maybe reading the source code can help.
openfoam 2.1.1, volscalarmatrix
Adding an internal heat source for compressibleTwoPhaseEulerFoam Kenna OpenFOAM Programming & Development 3 September 17, 2013 04:51
