June 28, 2019, 03:38 |
How can i get faceSet averagedScalar?
Rep Power: 8 |
Hi!
I use OF v2.3.1, modify rhoReactingBuoyantFoam. Now I want to get weightedAverageVaue of internal Face species. so, I make faceSet which I need weightedvalue of species , by using topoSet. then I try coding, but I cannot get it! (first,I cannot be recognized faceSet. Now I know, cellSet can be recognized as follow cellSet Any(mesh,"cellSetName"); ) and I want to do like follows. ------------------------------------------------------------- forAll(face(),fid) { if (Any[fid]){ sumOfRhoYValue += fvc::interpolate(Y.Air)[fid] * fvc::interpolate(rho)[fid]; sumOfRhoYValue += fvc::interpolate(rho)[fid]; } } weightedAverage=sumOfRhoYValue / sumOfRhoValue; --------------------------------------------------------------- I know the above has lots of misktake, but i don't know what should I do... can anyone help me ? regard. |
average field, facesets, openfoam2.3.1 |
[mesh manipulation] Add / Remove faces from patch , create new | djh2 | OpenFOAM Meshing & Mesh Conversion | 9 | November 8, 2020 16:30 |
topoSet ; faceSet and cellSet | Raza Javed | OpenFOAM Running, Solving & CFD | 2 | July 24, 2019 06:56 |
[Commercial meshers] faceSet of a cutting plane for a internal patch definition | RubenGutiii | OpenFOAM Meshing & Mesh Conversion | 1 | April 17, 2019 05:10 |
select disk with faceSet | raffale | OpenFOAM Pre-Processing | 4 | June 8, 2012 08:27 |
[swak4Foam] Mass flow rate through faceSet using swak4foam | CedricVH | OpenFOAM Community Contributions | 5 | May 4, 2012 07:57 |
