Openfoam BC error
Old   June 17, 2019, 05:31
Post Openfoam BC error
chunliang
generalKEE is on a distinguished road
When I used my own written boundary conditions for calculations, I had a strange error. Could someone help me?
Create time
Create mesh for time = 0
PISO: Operating solver in PISO mode
Reading transportProperties
Reading field p
Reading field U
Reading field C
Starting time loop
Time = 5e-05
Courant Number mean: 7.5e-05 max: 0.194817
        smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 2.38974e-06, No Iterations 8
        smoothSolver:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#5  Foam::newFvPatchScalarField::updateCoeffs() at ??:?
#6  Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
#7  Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#8  Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#9  ? at ??:?
 #10  ? at ??:?
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12  ? at ??:?
generalKEE is offline   Reply With Quote
Old   June 17, 2019, 08:13
mtgoncalves is on a distinguished road
This line:
indicates that an error occured related to floating-point arithmetics.
This line:
indicates that the error occured during the call to the function Foam::divide. Whether you called this function yourself or not you are facing a division error. You are probably dividing by 0 or by NaN. Make sure that you are not accidently dividing by zero. Check all the values of the variables by which you are dividing.
mtgoncalves is offline   Reply With Quote
Old   June 18, 2019, 06:59
Default another question
chunliang
thanks for your help. Today, i meet another problem
myicoFoam: symbol lookup error: /home/a/OpenFOAM/a-5.x/platforms/linux64GccDPInt32Opt/lib/libnewFvPatchScalarField.so: undefined symbol: _ZN4Foam21newFvPatchScalarFieldC1ERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE
Old   June 18, 2019, 08:26
Undefined symbol means that there is a type which is not defined. I see you have developed your own solver myicoFoam and your own library for a BC called newFvPatchScalarField. As the lib is being picked up during compiling but some symbol is unknown I suspect that maybe the header file is not being picked up. It is hard to tell without seeing your Make/files and Make/options files.
boundary condition error
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
