Coupling Openfoam and PyTorch
Old   June 14, 2019, 13:42
Default Coupling Openfoam and PyTorch
scientium is on a distinguished road
Hello Foamers,
I am trying to couple OpenFOAM and PyTorch (C++ API). I am almost done except one final bit.
I am using cmake to compile the libraries together. I am trying to build the laplacianFOAM with PyTorch. In the CMakeLists.txt file, I must include
find_package(Torch REQUIRED)
to include torch (of course!!).
This works well if I do not have any IOobject in my source. I am consistently getting the following error during compilation.
CMakeFiles/mylaplacianFoam.dir/laplacianFoam.C.o.data.rel.ro._ZTVN4Foam8OPstrea mE[_ZTVN4Foam8OPstreamE]+0x80): undefined reference to `Foam::UOPstream::writeQuoted(std::string const&, bool)'
collect2: error: ld returned 1 exit status
CMakeFiles/mylaplacianFoam.dir/build.make:97: recipe for target 'mylaplacianFoam' failed
make[2]: *** [mylaplacianFoam] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/mylaplacianFoam.dir/all' failed
make[1]: *** [CMakeFiles/mylaplacianFoam.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
More specifically, while compiling the solver, the following declaration
volScalarField T
IOobject
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
gives me the said error. If I comment out the IOobject declaration, I do not face any compilation error. I also do not get any compilation error if I use wmake (without torch library, haven't tried that route yet).
So, I have two questions.
1. Why is this error cropping up when I include the PyTorch libraries?
2. Is there another way in which I can read the T data without using IOobject?
EDIT:: Found the cause of the problem. It seems that the flag -D_GLIBCXX_USE_CXX11_ABI needs updating from 0 to 1. However, it still does not solve the problem. It still gives compilation error. I looked up the internet and it seems that either I have to recompile my openfoam or compile mylaplacianFoam with both the flags. Anyone knows how to do either of these things?
Last edited by scientium; June 15, 2019 at 02:05. Reason: Made progress on debugging
scientium is offline   Reply With Quote
Old   March 30, 2024, 07:08
serg
kont87 is on a distinguished road
Did you find a solution?
Kind regards
kont87 is offline   Reply With Quote
c++, compiling, pytorch
