Selective patches in dynamicInkJetFvMesh
Old   May 27, 2019, 12:49
Default Selective patches in dynamicInkJetFvMesh
Joaquín Aranciaga
joaran is on a distinguished road
Hello everyone!
I'm modifying the dynamicInkJetFvMesh solver for moving the mesh following a specific function of time and space. I'm able to do that without problems, but here's what's been troubling me. I have a sliding surface, and I need to move only the points belonging to one of the patches, while the adjacent patch remains still. So, I cannot filter the points based solely on their locations, because that way points belonging to both of the surfaces move.
What I attempted to do is to load the faces:
faceIOList faces_;
    faces_
        IOobject
            "faces",
            io.time().constant(),
            meshSubDir,
            *this,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
And then I intend to load the boundaries, and do a loop over the faces gathering the points that belong to the faces that belong to a given patch name, say "movingPlane".
So, my questions would be:
How may I load the boundaries from the boundary file exported by polymesh? i.e. I'm looking for something analogous to the code I wrote for the faces.
Once loaded that file, how can I access the "movingPlane" patch and get their startingFace and number of faces?
Given that, how can I access the components of a given face to get the points that make the face? Until now, I've managed to access a specific line in the "face" list, but it gives me something like " 4 (12 60 23 90)", and I'd need to get 12, 60, 23 and 90 separately.
Ps: I've already tried the Laplacian solvers for both displacement and velocity, and both explode at some time (the domain becomes highly non-orthogonal), and besides, I already know the prescribed movement of the nodes.
Thank you very much for taking the time to read this post!
Joa.-
joaran is offline   Reply With Quote
Old   May 27, 2019, 16:36
Joaquín Aranciaga
Originally Posted by joaran View Post
Hello everyone!
faceIOList faces_;
    faces_
        IOobject
            "faces",
            meshSubDir,
            *this,
            IOobject::NO_WRITE
Joa.-
Hi all,
I've managed to answer question #3. To access a specific element of a row of a list, it's as simple as listName[i][j].
For the moment I've circumvented the problem by looping at faces manually written by me (after looking at the boundary file. The problem is that every time I refine the mesh, or change it in any way, I have to manually change those numbers and recompile it. But the silver lining is that it takes oneself out of the hurry, in case we don't know the right way to do it.
Greetings!
Joa.-
dynamicinkjetfvmesh, mesh motion, openfoam
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 09:19
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 23:35
