reactingOneDim21CharOxi - fireFoam-Dev
Old   May 17, 2019, 02:19
Default reactingOneDim21CharOxi - fireFoam-Dev
Archana V is on a distinguished road
My project work is on oxidation reaction of metal with steam. For this purpose, I have modified chtMultiRegionFoam (version 6) by including pyrolysis model. But this pyrolysis model takes care only below reaction
solid1 = solid2 + gas.
The reaction that I am trying to solve is solid1 + gas1 = solid2 + gas2. For this, I have found reactingOneDim21CharOxi (fireFoam-dev) is suitable. While compiling library function, Below statements are giving troubles.
const label charIndex = solidThermo_.composition().species()["char"];
scalar rhoChar = solidThermo_.composition().rho(charIndex, 10000, 298);
dimensionedScalar Cp0("Cp0", dimEnergy/dimMass/dimTemperature, solidThermo_.composition().Cp(0, 1.0e05, 300.) );
dimensionedScalar Cp1("Cp1", dimEnergy/dimMass/dimTemperature, solidThermo_.composition().Cp(1, 1.0e05, 300.) );
The error is
'class Foam:: autoPtr<Foam:: solidReactionThermo>' has no member named composition
The base class is reactingOneDim instead of reactingOneDim21 which is used in fireFoam-dev.
The constructors used in reactingOneDim are different from reactingOneDim21.
In reactingOneDim - these statements are used :solidThermo_(solidReactionThermo::New(regionMesh( ))), solidChemistry_(basicSolidChemistryModel:: New(solidThermo_())),
while in reactingOneDim21, statements are: solidChemistry_(basicSolidChemistryModel::New(regi onMensh())), solidThermo_(solidChemistry_solidThermo())
Kindly give some insight view about this topic, which will be highly helpful for my research.
Thank you
Archana V is offline   Reply With Quote
Old   May 17, 2019, 02:44
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Archana,
For my topic of research, I combined chtMultiRegionFoam and firFoam (Solid model alone).
As you stated, only [solid1 = solid 2 + gas] defined by default in the reacting one dimensional solid solver. i.e., one solid on the L.H.S and one solid on R.H.S with only 1 gas can be defined. In addition, no stoichiometric coefficients can be defined in solid model unless and until it is defined and declared in solid chemistry model.
I recommend you to refer biomassGasificationFOAM source files below, where you can fit the expected global reaction with coefficients.
https://www.researchgate.net/publica...tallPack_10tar
Hope it helps. Thank you^^
Kummi is offline   Reply With Quote
Old   May 17, 2019, 03:40
Thanks. I will look into it.
Old   May 17, 2019, 05:58
ANKUR GARG
ankur_garg is on a distinguished road
I hope, you are clear with the error? And you know some of C++ already?
ankur_garg is offline   Reply With Quote
Old   May 17, 2019, 13:58
I suppose, in solidReactionThermo (version-6), there is no member function of composition. I am able to compile with OpenFOAM-4, but not with OpenFOAM-6. I am new to C++.
Old   May 17, 2019, 14:07
ANKUR GARG
Yes. You are actually right. OpenFOAM4 is much stable version than 6. You can go ahead with 4. Moreover, if you want to learn more through debugging, I would suggest you to use OpenFOAM ESI version like OpenFOAM-v1612+ and more. Build that in debug mode which you can change in etc/nashe file. I hope you are not new to OpenFOAM!
Old   May 17, 2019, 14:08
ANKUR GARG
Etc/bashrc. Sorry it was autocorrect, not me!
Ankur Garg
Old   May 18, 2019, 02:42
Thanks Ankur.
Error with the FireFOAM examples farensheep OpenFOAM Bugs 3 July 25, 2015 16:54
fireFoam installation Roman1 OpenFOAM Installation 2 September 27, 2013 04:05
Install/compile fireFoam 1.6-1.0 in Openfoam 2.1.1 hz283 OpenFOAM Programming & Development 19 April 1, 2013 09:35
How to setup a proper "heatFlux" boundary for fireFoam? Jumping OpenFOAM Pre-Processing 0 March 27, 2013 10:27
pyrolysis in fireFoam windwin OpenFOAM 1 September 26, 2011 09:11
