liquidEvaporation in simpleReactingFoam
Old   May 16, 2019, 20:37
Default liquidEvaporation in simpleReactingFoam
Nilay Kulkarni
neilk is on a distinguished road
I am trying to model mass transfer phase change in simpleReactingFoam. When setting the properties in the reactingCloudProperties in solution for either transient - yes or no:
    active          true;
    coupled         no;
    transient      no; //yess
   calcFrequency   1;
    cellValueSourceCorrection no;
    //maxCo           1;
     maxTrackTime 		1;
      resetSourcesOnStartup	false;
For Steady, the diameter get reset to the original injected diameter but the dt used for the dMassPC calculation remains 1.
Solving 3-D cloud reactingCloud1
Cloud: reactingCloud1 injector: model1
    Added 1 new parcels
Ni = 1.80455e-11 d= 4e-06 dt = 1
    Current number of parcels       = 1
    Current mass in system          = 4.646091741e-14
    Linear momentum                 = (8.545341647e-20 3.137059054e-22 1.413548384e-22)
   |Linear momentum|                = 8.54541092e-20
    Linear kinetic energy           = 7.858653236e-26
    Injector model1:
      - parcels added               = 1
      - mass introduced             = 4.691445029e-14
    Parcel fate: system (number, mass)
      - escape                      = 0, 0
    Parcel fate: patch INLET (number, mass)
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate: patch TOP (number, mass)
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate: patch BOTTOM (number, mass)
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate: patch OUTLET (number, mass)
      - escape                      = 0, 0
      - stick                       = 0, 0
    Parcel fate: patch WALL (number, mass)
      - escape                      = 0, 0
      - stick                       = 0, 0
    Temperature min/max             = 300, 300
    Mass0 = 0
 dMass = 4.535328818e-16
    Mass transfer phase change      = 4.535328818e-16
    Mass transfer devolatilisation  = 0
    Mass transfer surface reaction  = 0
smoothSolver:  Solving for Ux, Initial residual = 0.03017707843, Final residual = 0.002718135185, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.9966951568, Final residual = 0.06951720496, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.2575426795, Final residual = 0.01208645105, No Iterations 2
surfaceFieldValue surfaceFieldValue1 write:
    sum(BOTTOM) of H2O = 0
    sum(BOTTOM) of air = 19238
Time = 2
    Added 1 new parcels
Ni = 1.804549861e-11 d= 4e-06 dt = 1
    Current mass in system          = 4.646091745e-14
    Linear momentum                 = (2.536591448e-20 -6.572352722e-19 -1.02175801e-19)
   |Linear momentum|                = 6.656136469e-19
    Linear kinetic energy           = 4.76789473e-24
    Injector model1:
      - parcels added               = 1
Where as when I put solution method as transient, it gives out multiple iterations for every timestep and it solves for mass transfer multiple in the 1st time step:
Time = 1
 Entered the transient time loop here
Ni = 1.80455e-11 0 4e-06dt = 1
    Added 1 new parcels
Ni = 1.804549861e-11 4.535328818e-16 3.987068597e-06dt = 1
    Current mass in system          = 4.600885077e-14
    Linear momentum                 = (8.198791097e-20 -1.215618056e-22 1.352201464e-22)
   |Linear momentum|                = 8.19881126e-20
    Linear kinetic energy           = 7.305171174e-26
    Injector model1:
      - parcels added               = 1
      - escape                      = 0, 0
      - escape                      = 0, 0
      - stick                       = 0, 0
      - escape                      = 0, 0
      - stick                       = 0, 0
      - escape                      = 0, 0
      - stick                       = 0, 0
      - escape                      = 0, 0
      - stick                       = 0, 0
      - escape                      = 0, 0
      - stick                       = 0, 0
    Mass0 = 0
 dMass = 9.055995246e-16
    Mass transfer phase change      = 9.055995246e-16
smoothSolver:  Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 20
smoothSolver:  Solving for h, Initial residual = 0.9999999996, Final residual = 0.02940408779, No Iterations 2
Time = 2
Ni = 1.804549722e-11 9.055995246e-16 3.97409498e-06dt = 0.7257109082
Ni = 1.804549621e-11 1.23260168e-15 3.964657458e-06dt = 0.2742890918
    Current mass in system          = 4.555854866e-14
    Linear momentum                 = (1.200638905e-19 -1.249845965e-18 -2.45281995e-21)
   |Linear momentum|                = 1.255601963e-18
    Linear kinetic energy           = 1.730231028e-23
    Injector model1:
      - parcels added               = 1
Is there a way to make sure that the diameter of the particle gets updated after every time step according to the dMassPC and make sure that it calculates dMassPC only once every time step?
Thank you
neilk is offline   Reply With Quote
liquidevaporation, phasechange, reactingcloud, simplereactingparcelfoam
LiquidEvaporationBoil & LiquidEvaporation amirhoshangm OpenFOAM Programming & Development 2 July 31, 2019 06:03
cyclone-case with lower outlet using simpleReactingFoam (steady-state) jango OpenFOAM Running, Solving & CFD 3 April 17, 2018 06:06
LiquidEvaporation and Particle&Wall Interaction liliu OpenFOAM 1 March 6, 2017 10:02
