develloping an overtSet solver with only one region |
May 16, 2019, 06:21 |
Fabien Robaux
Rep Power: 10 |
Hello foamers,
I am currently working on a coupling between an external solver and OpenFoam (17.12). I don't have an important background to the development in OpenFOAM, even if I have already written a couple of small solvers. I searching for leads to follow. I have all the results of this external solver (in the OpenFoam format, ie results are in 0/ 0.025/ 0.050...) and I want OF to import them and work with them. I would like to use a different mesh and a different time step. The mesh coming from outside is overlapping the one i'll solve the problem on. I was thinking about using a region decomposition, such that one region is the "background" external part with real only, and one is the solved region. I've also seen the overSet possibilities. And I think It could be a good idea to incorporate the multiRegions possibilities in overInterFoam. The problem is from what I understood the latest use Cellset where multiRegion use Cellzone (and of course region). Will it be possible to use the tools from overSet on a multiRegion mesh? Would you have an idea where I should go look for? |
cellset, coupling, overset, region |
How to know if solver is considering my porous region? | deepbandivadekar | OpenFOAM Running, Solving & CFD | 1 | November 5, 2018 13:03 |
How to let the mesh motion solver just solve a small region near a moving boundary? | zhajingjing | OpenFOAM Running, Solving & CFD | 9 | April 28, 2016 04:15 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
