argument deduction/substitution failed when calling fvc::ddt
Old   May 8, 2019, 13:51
Question argument deduction/substitution failed when calling fvc::ddt
Yu Zhang
Zhangyy is on a distinguished road
I am trying to compute the residual of kEqn given the data for U, k and Reynold stress. So, I modified the original kEqn:
tmp<fvScalarMatrix> kEqn
fvm::ddt(alpha, rho, k_)
+ fvm::div(alphaRhoPhi, k_)
- fvm::laplacian(alpha*rho*DkEff(F1), k_)
alpha()*rho()*Pk(G)
- fvm::SuSp((2.0/3.0)*alpha()*rho()*divU, k_)
- fvm::Sp(alpha()*rho()*epsilonByk(F1, F23), k_)
+ kSource()
+ fvOptions(alpha, rho, k_)
to
kResidual_ = fvc::ddt(alpha, rho, k_)
+ fvc::div(alphaRhoPhi, k_)
- fvc::laplacian(alpha*rho*DkEff(F1), k_)
- alpha()*rho()*Pk(G)
+ fvc::SuSp((2.0/3.0)*alpha()*rho()*divU, k_)
+ fvc::Sp(alpha()*rho()*epsilonByk(F1, F23), k_)
- kSource()
- fvOptions(alpha, rho, k_);
Here, I changed all the fvm to fvc, as kResidual should be calculated explicitly.
However, it complains that
" template argument deduction/substitution failed:
cannot convert ‘alpha’ (type ‘const alphaField {aka const Foam::geometricOneField}’) to type ‘const volScalarField& {aka const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&}’ "
I looked at the definition of function fvcDdt in ddtScheme.C, which is
template<class Type>
tmp<GeometricField<Type, fvPatchField, volMesh>> ddtScheme<Type>::fvcDdt
const volScalarField& alpha,
const volScalarField& rho,
const GeometricField<Type, fvPatchField, volMesh>& vf
NotImplemented;
return tmp<GeometricField<Type, fvPatchField, volMesh>>
GeometricField<Type, fvPatchField, volMesh>::null()
The type of alpha is indeed inconsistent with that in kEqn. In fact, I have the same problems when calling fvc::SuSp and fvc::Sp.
I also found that the function fvmDdt has the same argument declarations:
tmp<fvMatrix<Type>> ddtScheme<Type>::fvmDdt
NotImplemented;
return tmp<fvMatrix<Type>>
new fvMatrix<Type>
vf,
alpha.dimensions()*rho.dimensions()
*vf.dimensions()*dimVol/dimTime
My question is
1) How can I fix this problem?
2) Why there is no error occurring when calling fvm::ddt?
Thanks,
ZhangYY
Last edited by Zhangyy; May 8, 2019 at 13:54. Reason: make the question more clear
Zhangyy is offline   Reply With Quote
fvc::ddt(), openfoam 6, programing
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
