Non linear Source Term, InterphaseChangeFoam, MULES |
May 7, 2019, 11:38 |
Philipp
Rep Power: 7 |
Hallo everyone,
I am working on the InterCondensatingEvaporatingFoam, which uses the "alphaEqnSubCycle.H" and "alphaEqn.H" from the InterphaseChangeFoam. The original solver is written like follows: Code:
fvScalarMatrix alpha1Eqn ( fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1) + fv::gaussConvectionScheme<scalar> ( mesh, phi, upwind<scalar>(mesh, phi) ).fvmDiv(phi, alpha1) - fvm::Sp(divU, alpha1) == fvm::Sp(vDotvmcAlphal, alpha1) + vDotcAlphal ); d(alpha)/dt+v*div(alpha)=(S_vap-S_con)*alpha+S_con My frist question is about the RHS. The expression can be rewritten as: (S_vap-S_con)*alpha+S_con=S_vap*alpha+S_con(1-alpha). However, I want to change the linear dependency on the right HS like: S_vap*sqrt(alpha)+S_con(1-sqrt(alpha)). Does anyone of you know, how it is possible to change the source Code to use a non linear source term? The source term will decrease the values of alpha, so I think this is the reason why it is treated in an implicit way. The second question is about MULEs. Original Code: Code:
volScalarField alpha10("alpha10", alpha1); for (int aCorr=0; aCorr<nAlphaCorr; aCorr++) { tmp<surfaceScalarField> talphaPhiCorr ( fvc::flux ( phi, alpha1, alphaScheme ) + fvc::flux ( -fvc::flux(-phir, alpha2, alpharScheme), alpha1, alpharScheme ) ); if (MULESCorr) { talphaPhiCorr.ref() -= talphaPhi(); volScalarField alpha100("alpha100", alpha10); alpha10 = alpha1; MULES::correct ( geometricOneField(), alpha1, talphaPhi(), talphaPhiCorr.ref(), vDotvmcAlphal, ( divU*(alpha10 - alpha100) - vDotvmcAlphal*alpha10 )(), 1, 0 ); MULES is called after solving the equation mentioned above to guarantee boundedness. I think one problem is, that I do not completly understand what MULES is doing, but in my opinion it doesn't work. If I get for example a value for alpha=-1*e^-5 (which is lower than the physical limit of alpha, which is in the region of 0 to 1), the value after running MULES does not change. |
Source Term due to evaporation in energy transport equation | styleworker | OpenFOAM Programming & Development | 3 | September 7, 2022 04:09 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
