April 2, 2019, 12:51 |
Simple question on dynamic meshes
Rep Power: 7 |
I presume most users of this forum know that Foam allows modifications to the mesh topology when the relative position of solids changes ( e.g. rotating devices like fans, compressors)
But what about altering it depending on the current numerical solution in a domain ? For example, if a solution gradient is greater than a given threshold at a given cell, it would be nice if one could refine the mesh around that cell. And make it coarser when the solution gradient will later be less than the given threshold. Best, Marc |
April 3, 2019, 09:26 |
Marius Bünker
Rep Power: 9 |
It can be pretty easily done using the Mesh Refinement from dynamicFvMesh. Check out the DamBreakWithObstacle tutorial...
April 4, 2019, 11:43 |
Rep Power: 7 |
I checked that the source code for the dam break tutorial indeed includes refinement. I don't understand it enough yet to figure out if it can be adapted to some arbitrary threshold on a solution gradient as in my example, but it's a start. Thanks for the info, Marius.
Dynamic Meshing of Simple 2D Geometry | harman79 | FLUENT | 2 | January 17, 2018 07:07 |
Dynamic Meshes | Arturo | FLUENT | 2 | May 13, 2008 07:23 |
question about dynamic meshes | zhhwoo | FLUENT | 0 | August 2, 2006 23:36 |
Dynamic Meshes with Mixture Model | cfdtoy | FLUENT | 3 | April 13, 2004 22:16 |
Dynamic Meshes | Cfdtoy | FLUENT | 2 | February 6, 2004 13:14 |
