How to set the value of a varying coefficient on cell faces
Old   March 24, 2019, 07:27
Default How to set the value of a varying coefficient on cell faces
Wenming Yang
ywem is on a distinguished road
Dear Foamers
In my case, there is a coefficient which varies with the calculated quantity. It has the following form on cell faces,
mue=[fe/muE+(1-fe)/muP]^-1
where fe is the distance form the cell face to one cell center, muE and muP are the values of the coefficient defined on two neighbour cell centers, respectively.
Can anyone help me for how to set this coefficient on cell faces?
Thank you in advance.
ywem is offline   Reply With Quote
boundary coefficient
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
