InterPhaseChangeFoam, alpha Eqn.
Old   March 15, 2019, 13:02
Default InterPhaseChangeFoam, alpha Eqn.
Philipp
Phigo90 is on a distinguished road
Hi everyone,
I am trying to understand the equation system, which is solved by the InterCondensatingEvaporatingFoam.
First I want to understand the alphaEqn. The implemented header File ("alphaEqn.h) ist from the "interPhaseChangeFoam" (Path:$(FOAM_SOLVERS)/multiphase/interPhaseChangeFoam)).
However, first of all I try to understand the following part
  if (MULESCorr)
        fvScalarMatrix alpha1Eqn
            fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1)
          + fv::gaussConvectionScheme<scalar>
                mesh,
                phi,
                upwind<scalar>(mesh, phi)
            ).fvmDiv(phi, alpha1)
          - fvm::Sp(divU, alpha1)
            fvm::Sp(vDotvmcAlphal, alpha1)
          + vDotcAlphal
        alpha1Eqn.solve();
        Info<< "Phase-1 volume fraction = "
            << alpha1.weightedAverage(mesh.Vsc()).value()
            << "  Min(" << alpha1.name() << ") = " << min(alpha1).value()
            << "  Max(" << alpha1.name() << ") = " << max(alpha1).value()
            << endl;
        talphaPhi = alpha1Eqn.flux();
Does anyone of you know a literature reference within which this part is explained or still better, the whole "alphaEqn.H" file?
If not, can anyone answer the following questions?:
1) Is there a difference between "fvmDdt" and "fvm::ddt". Ddt could be the material derivative (because of the capital "D"), but it does not make sense in this context.
2)The second and third part of the LHS of the alpha equation are:
                mesh,
                phi,
In my view, this lines corresponds to: div(v*alpha)-div(v)*alpha, whereby v is the velocity vector and alpha the phase fraction. With the product rule this term can be rewritten as v*grad(alpha). Is this correct? Can anyone explain this parts? In my view it should be div(v*alpha) without the third term on the RHS.
3) With the above-mentioned comments, the alphaEqn can be written in my view as:
d/dt(alpha)+v*grad(alpha)=V_cond(1-alpha)+V_vap*alpha (Note that d/dt is the partial derivation)
Do I understand this in the right manner?
Kind regards from Germany and thanks for your help!
Phigo90 is offline   Reply With Quote
Old   May 29, 2020, 07:17
Philipp
I am still interested in solving this problem =)
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
How to solve this alpha Eqn using MULES? keepfit OpenFOAM Running, Solving & CFD 3 July 11, 2015 06:57
Implementation of Temperature Eqn in InterPhaseChangeFoam Jibran OpenFOAM Running, Solving & CFD 14 June 17, 2015 11:47
Why we subtract continuity Eqn into momentum Eqn instead of adding it? sharonyue OpenFOAM Programming & Development 7 June 4, 2015 06:20
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM keepfit OpenFOAM 4 January 31, 2014 15:32
