BC for inlet angle for velocity
Old   February 19, 2019, 04:23
Default BC for inlet angle for velocity
BC
Tarun BC is on a distinguished road
Hi guys
I'm facing an issue in fixing the BC for inlet angle for velocity. Solver used is buoyantBounessqsimplefoam.
so I kindly request to help me out with this. If possible kindly attach the file too.
Thank you
Tarun BC is offline   Reply With Quote
Old   February 19, 2019, 06:18
Gareth
bullmut is on a distinguished road
Hi Tarun
I think you will get a better response if you provide some details on what you are trying to do, or even the files you are using.
this way users can run your case or more easily visualize your problem.
your request as it is now doesn't tell us much.
bullmut is offline   Reply With Quote
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 15:00
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 03:39
Winglet cant angle effects frossi FLUENT 0 March 31, 2017 20:35
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 18:24
