mapped boundary condition in multi-region solvers
Old   February 13, 2019, 08:09
Default mapped boundary condition in multi-region solvers
Benedetto Di Paolo
benedip is on a distinguished road
I’m trying to exchange information between two boundaries (mappedWall types) in a multi-region approach. I built separately the two regions (domain1 and domain2) by means of two blockMeshDicts. A similar approach can be found in the following tutorial case:
OpenFOAM-v1812/tutorials/heatTransfer/chtMultiRegionSimpleFoam/heatExchanger
I transferred the velocity field U from patch1 (mappedWall at the outlet of domain1) to patch2 (mappedWall at the inlet of domain2). I achieved it easily this by mapping velocity on patch1 and by fixing it on patch2 in a similar way to the mappedVelocityFluxFixedValue B.C. So B.C. ends like:
  operator==(patch1UField);
 fixedValueFvPatchField<vector>::updateCoeffs();
Thus, I obtained patch1UField = patch2UField. So far no problems.
Now, If I look at the velocity field just a little bit far from patch2 (in domain2), I find completely different values from the ones I fix (patch1UField). It’s like if my value didn’t come out from patch2.
Finally I can obtain the expected values at the neighboring patch cells (patch().faceCells()) by applying this B.C. (by fixing the patch values and the internal cells values), as follows:
 Field<vector>& intFld = const_cast<Field<vector>&>(this->primitiveField());
 UIndirectList<vector>(intFld, this->patch().faceCells()) = patch1UField;
Does anybody know how to fix this problem?
I just want to fix the velocity on the patch without pushing internal cells values.
Thanks you
Best regards,
Benedetto
p { margin-bottom: 0.1in; line-height: 120%; }a:link { } p { margin-bottom: 0.1in; line-height: 120%; }a:link { }
benedip is offline   Reply With Quote
fixed value, fixed velocity, mappedboundarycondition, multi regions, openfoam 1806
Mapped Boundary Condition louistse OpenFOAM 5 June 1, 2018 09:23
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 20:13
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
