February 12, 2019, 17:58 |
What is ".*" in pointDisplacement file?
Andrew Somorjai
Rep Power: 13 |
Hello all,
I just wondered if ".*" means "for all" patches in this snippet from a pointDisplacement file; kind of like in SQL where you use something like "select * from ..."? Code:
boundaryField { ".*" { type uniformFixedValue; uniformValue (0 0 0); } |
February 12, 2019, 18:04 |
Mark Olesen
Rep Power: 40 |
It is a regex (regular expression) - POSIX flavour.
February 12, 2019, 18:06 |
Andrew Somorjai
Rep Power: 13 |
February 12, 2019, 18:54 |
Rep Power: 15 |
Yes. You could test this by removing it -- should trigger a crash and a message to the effect of "patch not defined in pointDisplacement.boundaryField".
Caelan |
February 12, 2019, 19:19 |
#5 | |
Andrew Somorjai
Rep Power: 13 |
"s.* matches s followed by zero or more characters, for example: "s" and "saw" and "seed"." |
patch, select, types |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 22:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
