new boundary condition, similar to variableHeightFlowRateInletVelocity |
February 8, 2019, 11:27 |
Martin Hübner
Hi everyone,
I am interested in modifying the existing boundary condition 'variableHeightFlowRateInletVelocity'. This BC may be used as Code:
{ type variableHeightFlowRateInletVelocity; flowRate 0.2; value uniform (0 0 0); // placeholder } Now, suppose a pipe with one inlet and one outlet. At the inlet, both phases occupy half of the inlet patch, initially. When the flow starts, I would like to adjust the height of the occupied region due to the specified volumetric flows of both phases. So, what happens is that the heights adjusts but the velocity of the other phase is set to zero. Is there a way to set a constant volumetric flow to the other phase? Hopefully, someone is interested enough to understand my problem Cheers, Martin |
February 8, 2019, 19:15 |
#2 | |
Andrew Somorjai
Rep Power: 13 |
I'm just not sure what you mean by "heights adjusts" and do you mean phase as in air and water? |
boundary condition, interfoam, two phase annular flow |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Similar boundary condition to zero flux condition | Navip | OpenFOAM Running, Solving & CFD | 0 | August 13, 2015 04:04 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
