Implementation of adjoint equation
Old   February 1, 2019, 10:28
Default Implementation of adjoint equation
Alexis Courtais
Berilmun is on a distinguished road
Hi everyone,
I am trying to implement the following equation within OpenFOAM (Ua is the adjoint velocity) :
- \nu \DeltaUa+Ua\nabla U- (\nabla Ua) U + \nabla pa = -2 \nu\DeltaU
I tried the following implementation but I'm not sure it computes the adjoint equation above
  volTensorField gradU (fvc::grad(U));
  volVectorField adjointTransposeConvection2(gradU.T() & Ua);
  tmp<fvVectorMatrix> tUaEqn
        fvm::div(-phi, Ua)
        +fvm::Sp(fvc::div(phi),Ua)
        + adjointTransposeConvection2
        +turbulence->divDevReff(Ua)
         fvOptions(Ua)
            fvVectorMatrix& UaEqn = tUaEqn.ref();
            UaEqn.relax();
            fvOptions.constrain(UaEqn);
            solve(UaEqn == -fvc::grad(pa)-2*tau*fvc::laplacian(nu,U));
Do you have any tip about this implementation ?
Thanks in advance.
Berilmun
Berilmun is offline   Reply With Quote
Old   February 1, 2019, 12:02
Andrew Somorjai
massive_turbulence is on a distinguished road
Originally Posted by Berilmun View Post
Hi everyone,
        fvm::div(-phi, Ua)
         fvOptions(Ua)
            UaEqn.relax();
Thanks in advance.
Berilmun
Did you mix up Nabla and Delta for this part fvm::div(-phi, Ua) or the Laplacian and Divergence?
massive_turbulence is offline   Reply With Quote
Old   February 3, 2019, 12:18
Alexis Courtais
The convection term - \nu \DeltaUa is described by the term turbulence->divDevReff(Ua) in the code. The term fvm::div(-phi,Ua) is only modelling - (\nabla Ua) U. That's the point on which i'm not sure in my implementation.
Thank you for the reply.
Old   February 3, 2019, 15:59
Andrew Somorjai
The call to "turbulence->divDevReff(Ua) " is more than just \nu \DeltaUa
template<class BasicTurbulenceModel>
 Foam::tmp<Foam::fvVectorMatrix>
 Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff
     volVectorField& U
 ) const
     return
       - fvc::div((this->alpha_*this->rho_*this->nuEff())*dev2(T(fvc::grad(U))))
       - fvm::laplacian(this->alpha_*this->rho_*this->nuEff(), U)
Above code is line 91 from https://www.openfoam.com/documentati...8C_source.html
nuEff() is the effective viscosity.
dev2 is line 115 from https://www.openfoam.com/documentati...8C_source.html
Just use -fvm::laplacian(nu, Ua).
Old   February 3, 2019, 17:21
Alexis Courtais
     volVectorField& U
 ) const
     return
I'm working without turbulence model. I put "laminar" in my turbulenceProperties dictionary, so turbulence->divDevReff(Ua) will give me the same results than fvm::laplacian(Ua) ? I'm not right? I tried both and it gives me the same results. But you are right, it's better to put directly -fvm::laplacian(Ua). Thanks.
Do you have a tip to modeling the term (\nabla Ua)U?
Old   February 4, 2019, 16:33
Andrew Somorjai
My guess is it would be something like this fvm::Sp(fvc::laplacian(Ua), U)?
from here Understanding fvm::Sp()
What exactly is that term by the way, is Ua the flux?
Current conservation equation implementation miguelmontenegro Fluent UDF and Scheme Programming 3 July 3, 2024 08:21
Convective term in heat equation for rotating solids vabishek OpenFOAM Programming & Development 8 June 24, 2020 12:10
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 09:14
